ford_jake said:
Wondering if I can ditch the fan and run an electric only, just think it cleans up the engine compartment? Any thoughts, stock 200 6cyl
Additional cooling in hot environment can be helped with electric in addition to WP fan. Using
just elec. fan requires high CFM of big fan or multiples with thermostat sensor. A big advantage is the same maximum CFM at any speed regardless of engine RPM - even idling in traffic.
250 conversions in early cars can run out of any fan/radiator clearance with the longer snout 250.
