There are no specific drain holes.
If you just want to drain the system you would typically do it from the valve on the bottom of the rad.
But that won't get everything out, so the thing to do is pull that lower rad hose too.
The only other access in there are the 5 freeze plugs on the passenger side.
Hi JAGGUY.IIRC those plugs are the same thread size as the drain valve in the radiator.
If so,that would make a convienient drain plug for the block.
Good luck.Have fun.Be safe.
Leo
