Offenhauser 3x1 Build Thread
powerband
FSP Moderator
Re: Offenhauser 3x1 Build Thread
Post #101 by powerband » Mon Jan 07, 2019 6:41 pm
.. nothing is simpler than using a functioning OEM DSII system. The HEI 'trigger' module can be used with a DSII distributor as a simple option. for testing and/or builds.
1strodeo:
.. encouraging Tri-Power build thread, getting closer to the best part - the road (offroad?) tuning.
" Everything in my garage has a story ..."
wsa111
FSP Moderator
Post #102 by wsa111 » Mon Jan 07, 2019 7:22 pm
Both the MSD Box & HEI Module run on 12V. Allows a higher coil output.
Your DS11 distributor curve is a mystery. Yes the engine will run, but probably not to its peak potential. Bill
1strodeo
Post #103 by 1strodeo » Mon Jan 07, 2019 9:22 pm
wsa111 wrote:Both the MSD Box & HEI Module run on 12V. Allows a higher coil output.
This makes sense, but what is an MSD Box? Do I need one of those as well? And again how much to recurve a dizzy? Does any of this relate to the triple carb setup? I'm just trying to keep in mind this is a Bronco, which will spend the majority of it's life on the road, but certainly will not be running any 1/4 miles at the drag strip :lol:
Chad I'm not seeing how the HEI module is cheaper than a DSII module as I can get one at the yard for 10 bucks, although they're certainly not getting easier to find so availability I could see as an issue. Or how they're more reliable as I've known guys that have run DSII systems from junk cars for 10-20-30 years with no problem. Some even keep an extra module just in case, which again is 10 bucks. heck some even bolt them to the fender well so they can plug and play and keep going!! :beer:
In the grand scheme of things, I think maybe I should just stick with what I got until I get it running right. As stated by powerband and countless others throughout my journey the carb tuning is where the FUN happens :D
chad
Post #104 by chad » Mon Jan 07, 2019 10:15 pm
2 me the full DSII is the best. HEI adds a lill but it's preference - just like hair cuts'n liv. rm furniture.
Get the vehicle runnin on that center carb, go frm there. Make sure it's 1 ( all of'em) that can go on the gradients if its an 'off rder'.
Very last (cherry on top) is Bill's re-curve. A long wayta go...
Good Luck, we'll B watchin (if U B a'sharin).
:D
1strodeo
Post #105 by 1strodeo » Tue Jan 08, 2019 10:40 am
Econoline wrote:Nice work.
Someone makes an aluminum ring w/ a set screw to go from ford to the common chevy size air cleaner mouth, it's a lot nicer than the plastic ring adapters or otherwise if you need to find 3 that match
Does anyone know where I can find these adapters? I did not notice until recently that I only had one of the plastic ring adapters, thanks.
Econoline
Post #106 by Econoline » Wed Jan 09, 2019 1:28 am
I got that one on Ebay. I think I still have it, I can get some measurements for you if you need to make sure it's the right size.
It ain't gonna fix itself
1strodeo
Post #107 by 1strodeo » Wed Jan 09, 2019 2:27 pm
Thank you I will post my measurements tonight -jeff
1strodeo
Post #108 by 1strodeo » Wed Jan 09, 2019 8:34 pm
Here they are...thanks!
Econoline
Post #109 by Econoline » Thu Jan 10, 2019 12:09 am
A quick look has not turned up that adapter. I think it maybe out in the back of my van I'll look tomorrow. But I think it's the right size. iirc, it's 2 5/16" ID x 2 5/8" OD. A quick look didn't find them on Ebay last night.
Edit:
Found it! looks like speedway sells them:
https://www.ebay.com/itm/Small-Diameter-Air-Cleaner-Adapter-Ring-2-5-16-Inch-to-2-5-8-Inch/263920756172?hash=item3d72e725cc:g:Io0AAOSwuMZbkRvh:sc:USPSPriority!98221!US!-1:rk:32:pf:0
1strodeo
Post #110 by 1strodeo » Thu Jan 10, 2019 6:57 pm
Thanks man, I ordered 3 of them and 3 air filters. I went to the Speedway website because eBay had some shady language about contacting Speedway to ensure shipping would not be charged on each item, but there was no contact info! lol
1strodeo
Post #111 by 1strodeo » Sun Jan 20, 2019 7:17 pm
I got it running, but there were so many fuel leaks in the lines to the outer carbs I just removed the outers.
It will run but only if I'm giving it gas, it will not idle. I have electric pump pulling fuel from a gas can on the ground.
My question is, could vacuum leaks contribute to or cause this, like if the adapter is not completely sealed to the log?
1strodeo
Post #112 by 1strodeo » Sun Jan 20, 2019 7:21 pm
Also does anyone know of a part number or where to get the proper O rings? I've read somewhere in this thread about superior quality O rings, thanks.
Users browsing this forum: No registered users and 16 guests
