Alternative 200 six connecting rod
wsa111
FSP Moderator
Re: Alternative 200 six connecting rod
Post #51 by wsa111 » Tue Feb 25, 2020 6:10 pm
With over .515" lift with stock valve stem length your retainers are going to hit the valve guides.
Plus you will never get an installed valve spring height of 1.7" with stock valve length.
67 mustang,C-4, with mod. 80 hd, custom 500 cfm carb with annular boosters, hooker headers, dual exh.-X pipe, flowmaster mufflers, DSII dist. MSD-6425CL & MSD-Blaster 8252 Coil. Engine 205" .030" over with offset ground crank & 1.65 roller rockers. 9.5 comp., Isky 262 cam.
Sergeant82d
Post #52 by Sergeant82d » Tue Feb 25, 2020 6:15 pm
Aaannndddd... That's why I'm using custom titanium (int) and sodium-filled inconel (exh) valves with a 1.8 inch installed height.
I know I'm pretty new on the boards, and I'm certain you just want to help and in no way are trying to be the a@@h01# you sound like, but that doesn't mean I am new to building things.
I will cover the details in my build thread soon.
Firepower354
Post #53 by Firepower354 » Tue Mar 17, 2020 2:52 am
I don't find the 2018 update, but the 2006 one is one of my favorites for oddball research.
Feel free to delete if covered elsewhere.
http://www.guiaautomotrizcr.com/images/ ... manual.pdf
And of course the piston specs.
https://uempistons.com/c-29-silv-o-lite.html
It gets 10MPG, but goes up to 14 if I lie.
Users browsing this forum: No registered users and 17 guests
