In the picture I have a pick pointing to a hole on the fuel pump. When the pump moves in have a puff of air come out other wise the pump works fine. Is this normal. Thanks in advance
However if you have oil or fuel expel it would be time to replace the pump.
Remember to check your oil for fuel contamination with any fuel pump issues.
