Headers and dual exhaust
sprog777
Post #1 by sprog777 » Sat Mar 17, 2018 5:44 pm
I here there is a lot of drone using the flowmasters. What would be a good muffler to use instead. And can I run the gt exhaust pipe thru stock valance.
Re: Headers and dual exhaust
Post #2 by bubba22349 » Sat Mar 17, 2018 7:44 pm
I like the Turbo type mufflers. :nod:
chad
Post #3 by chad » Sat Mar 17, 2018 8:45 pm
there's at least 3 designs of 'mufflers'- chambered, turbo, glass pack...
I think the 'chambered' style is known 4 that (flowmaster) drone. Not too pleasant esp on a long trip.
As per bubba - try the turbo (I think it's a tube inside there, w/holes along the tube) they're reportedly better for that prob (and performance in many ford6 opinions). Our bud, Matt, at vintage inlines dot com can assist w/a purchase frm his stock. U could even put a resonator in there B4 the muffler to help the flowmaster...
U can have the 2 pipes go down the body & into a muffler or have a muffler for each side (1 or 2, ur choice).
DynoMax, Borla, Thrush have turbo style...however - many co.s (even these I believe) make all 3 varieties so double ck.
google for the 3 or 4 types for more info).
Good Luck & let us know how U do!
65coupei6
Assistant Admin
Post #4 by 65coupei6 » Sat Mar 17, 2018 11:41 pm
My Flowmaster's make long trips fun. :) They don't even bother my wife. But, if you don't want drone. You can also look into Widowmaker mufflers.
...Marco
'65 Mustang Inline 200. VI (CI) Aluminum Head, Holley 350, Schneider 264/274 cam,
Headers, DSII, MSD 6A, and a whole lotta other stuff!
Build That Six With Parts From VintageInlines.com
wsa111
FSP Moderator
Post #5 by wsa111 » Sun Mar 18, 2018 9:42 am
A crossover pipe or an X pipe will eliminate some of the drone.
If you can afford it Borla makes the best sound.
67 mustang,C-4, with mod. 80 hd, custom 500 cfm carb with annular boosters, hooker headers, dual exh.-X pipe, flowmaster mufflers, DSII dist. MSD-6425CL & MSD-Blaster 8252 Coil. Engine 205" .030" over with offset ground crank & 1.65 roller rockers. 9.5 comp., Isky 262 cam.
sprog777
Post #6 by sprog777 » Tue Mar 20, 2018 5:15 pm
Do you have to modify the z bar?
Users browsing this forum: B RON CO and 49 guests
