Late last week I dropped my spare head, a D5, off to my machinist to have it hot dipped and magnafluxed. When I get it back I'm going to take a 6" grinder and cut down the carb flange on it's angle into the high side of the log, ala stanyon. Then I'm going to clean it up with a file and use a bur to clean up the 'low side'.
My plan is to build a wooden box with scrap to hold the head and dry sand. Put the head in the grill and get it as hot as I can(It will get at least 7-800F), then brake out the torch to heat it up further and build the low side with bronze and braze on a 1/4" plate on for the tbi. I'll throw it in a bed of dry sand in the box when I'm done and then fill it with dry sand for the cool down. If all goes well I'll have the machinist face the plate on the mill and install SI portflow valves, hardened exhaust seats and 300 springs. I'll port it to before the valve job.
This is step #2 towards efi. Step 1 was welding in a bung for the O2 sensor when I made may new exhaust a couple weeks ago. Step 3 is an efi fuel tank. I've done alot of brazing in my career. But not on cast. I have bronze brazed cast, but only a small part once. I peened it right after and wrapped it with fiberglass exhaust wrap for the cool down. Still in service on my bandsaw.
This will take a while, but I'll update this thread as it progresses, for better or worse.
