"Something always leaking"
DoctorC
Post #1 by DoctorC » Tue May 07, 2019 5:15 pm
Hi All,
My new 67 has an oil leak somewhere, and a tranny leak somewhere. Before the purchase, I had a local mechanic hoist it so we could have a look see underneath, and for him to give me an idea of anything major wrong with it. After buying it, I asked him to change the oil and drop the pan so we could look for sludge, metal shavings, and have an idea if the engine has 62k, 162k or 262k miles by having a look see at the crankshaft (owner has no idea if it was ever rebuilt and is not sure if the dial has gone around yet).
In the follow up conversation, the mechanic (who has supposedly rebuilt a 66 and 68 in high scool) said that these things pretty much always leak from somewhere.
This struck me as odd. However, I've never had a 50 year old car before, so what do I know. Tolerances are never better that now, i get that. Materials too.
Any opinions on the matter from the local experts?
I'm hoping the new pan gasket, and tranny gasket will help. We'll see. I plan on pulling the head and cleaning the chambers and putting on a new gasket there too.
That otta do it, no?
1967 Cherry Red Mustang
Weber 32/36,
MSD 6AL+MSD Coil,
Duraspark 2 dizzy
chad
Post #2 by chad » Tue May 07, 2019 5:50 pm
4 me leaks R fun to figure out. I like problem solving (puzzles'n such).
Oil leaks R hard as driving blows the 'trail' around, gravity doesn't lie (usually). (In my home building/maintenance process at least travel didn't obscure location, &...)
So if U can clean Then not drive or start 4 awhile U may have a better chance to ID location. If need B I place a lrg cardboard (weighed dwn by rocks) under to observe location of leak. Come back in 1 day'n C. Trace upwards. Follow trail, use lght, mirror, what ever it takes. No leak? start'n run motor 1 min. Look again (now, even w/o moving - the fan may have moved the trail, 7 min the fam may not but block is still heated a lill, just a start will put it under pressure). Do not drive yet. Still no trail? make sure motor is clean (rags? pressure washer? solvent at car wash?) and drive a lill (5, 6 mi). Pull over cardboard again'n look.
Make sure ur senses tell U what type of leak it is: sweet - frm radiator; red, PS or tranny, black (blond/golden) crankcase, and so forth. Is it breaks? :hmmm:
DoctorC
Re: "Something always leaking"
Post #3 by DoctorC » Tue May 07, 2019 5:57 pm
The parking spot from the prev owner was not oil caked and there was no oil drip visible when I arrived to the cold engine. After warm up parked and a joy ride I noticed it glistened a little.
After hoisting it at the mechanic's, there as an obvious drip or two on the engine and the tranny. I'm thinking I'll steam clean / power wash the whole engine bay after driving it home (1.5hrs) and do what you suggest. If I'm lucky, the 2 gaskets he's replacing will do the trick. That's assuming these things don't *always* leak?
If not I should be ale to play detective =)
Weber 32/36,
MSD 6AL+MSD Coil,
Duraspark 2 dizzy
CZLN6
Post #4 by CZLN6 » Tue May 07, 2019 6:16 pm
Howdy Doc:
Enjoy the hunt. And no these old things don't always leak, but they do require TLC. Add the front and rear crank seals to your routine inspections. Good hunting.
DoctorC
Post #5 by DoctorC » Fri May 10, 2019 12:31 pm
Well it's good to know they're not permanent leakers =)
Turns out the mechanic, when he pulled the pan, didnt do anything other than clean it and note " the crank was ok". Which kinda sucks cuz I asked him to drop the pan and pull the bottom of a connecting rod to eval the crank for wear. Since I'm trying to assess the wear and tear. He did steam clan the engine bay tho, and paint the cover red to match the car. So there's that. He did not that the crank pulley was wiggly. So I ordered a new balancer to put on and overnighted it to him.
Oh well. I guess I'll have to do it myself. I'll drive it for 1k miles or so then do it. I planned on pulling the head over the next few weeks and cleaning the chambers and checking the valves anyway.I want new gaskets since it's leaking from somewhere...
I suppose I'll do a compression test, pull the head, clean it, clean the piston heads and check the chambers, put a new gasket and plugs, then see how she feels. Then maybe upgrade the distributor and Carb. We'll see.
I pick it up tomorrow and will have a good chance to see how she acts. It's a 1.5 hr highway drive home :thumbup:
Weber 32/36,
MSD 6AL+MSD Coil,
Duraspark 2 dizzy
[T00lbag]
Post #6 by [T00lbag] » Thu Sep 05, 2019 11:03 am
There is a saying in the Jeep world:
If it's not leaking...it's empty!
1964 Mercury Comet
1957 Jeep FC170 (Titled as a 1959)
chad
something always leaking (many things)
Post #7 by chad » Thu Sep 05, 2019 11:27 am
"... It's a 1.5 hr highway drive home..."
if shake dwn cruze 4 U w/this vehicle R there any contingency
plans? U given it a 20 min 1 yet, etc...
JackFish
Post #8 by JackFish » Fri Sep 06, 2019 11:28 am
Check the back of the valve cover.
It can drip there and seep down looking like a seal leak.
Yup, I bought another one.
1996 Chevy Caprice 9C1 (3)
1999 Dodge Ram 2500
DoctorC
Post #9 by DoctorC » Fri Sep 06, 2019 11:44 am
I just put on last week a new valve cover gasket. It's definetly leaking. I hammered it flat and used a cork gasket but looks like I'm gonna have to do more than that.
I did notice that it's leaking ALSO from the back and dripping down to the tranny. I smelled the oil on the tranny and it's not tranny fluid, it's engine oil. So that made me happy =)
I'll order some silicone gaskets off Summit and try them out next week.
Weber 32/36,
MSD 6AL+MSD Coil,
Duraspark 2 dizzy
wsa111
FSP Moderator
Post #10 by wsa111 » Fri Sep 06, 2019 12:01 pm
Make sure you have your pcv system operative, & make sure your breather cap is free flowing.
Spectre make a nice one. Bill
67 mustang,C-4, with mod. 80 hd, custom 500 cfm carb with annular boosters, hooker headers, dual exh.-X pipe, flowmaster mufflers, DSII dist. MSD-6425CL & MSD-Blaster 8252 Coil. Engine 205" .030" over with offset ground crank & 1.65 roller rockers. 9.5 comp., Isky 262 cam.
DoctorC
Post #11 by DoctorC » Fri Sep 06, 2019 1:28 pm
I can't seem to find the rubber/silicone ones anywhere online. Only cork.
Anyone got a pointer?
Weber 32/36,
MSD 6AL+MSD Coil,
Duraspark 2 dizzy
65coupei6
Assistant Admin
Post #12 by 65coupei6 » Fri Sep 06, 2019 9:58 pm
Valve Cover gasket? Vs12692 is cork. Vs12692r is rubber.
For the C4 use a lubelocker gasket for the pan
...Marco
'65 Mustang Inline 200. VI (CI) Aluminum Head, Holley 350, Schneider 264/274 cam,
Headers, DSII, MSD 6A, and a whole lotta other stuff!
Build That Six With Parts From VintageInlines.com
woodbutcher
Post #13 by woodbutcher » Sat Sep 07, 2019 4:36 pm
:D Fel-Pro also makes a"rubber"vc Gasket.Started using that brand way back in the mid 60`s.Have always been most satisfied.Your local parts house should stock them.
Good luck.Have fun.Be safe.
Leo
Otto von Bismarck
DoctorC
Post #14 by DoctorC » Sun Sep 08, 2019 10:36 am
The part number was very helpful. Turns out I can't find them because they're being discontinued, at least that's what the Rock Auto page says. I got their last one.
Weber 32/36,
MSD 6AL+MSD Coil,
Duraspark 2 dizzy
Post #15 by bubba22349 » Sun Sep 08, 2019 11:57 am
From your other post on valve cover leak did you take any pictures of the valve cover flange area after you cleaned off the old gasket? :nod:
I am hunting for a cheap project car to build up. My Ex-Fleet of Sixes sadly these are all long gone! :bang: 1954 Customline 223 3 speed with O/D, 1963 Fairlane project drag car with BB6, 1977 Maverick 250 with C4, 1994 F-150 a 300 with 5 speed.
JackFish
Post #16 by JackFish » Mon Sep 09, 2019 9:57 pm
DoctorC wrote:The part number was very helpful. Turns out I can't find them because they're being discontinued, at least that's what the Rock Auto page says. I got their last one.
I saw your post and checked it out,
i was able to order two of these without issue even though it said last one.
Couldn't pass it up for $2.50!
I think the "last one left" might be a marketing ploy.
Here is a page with parts for my '78 Fairmont.
Lots of general maintenance parts for the 200:
https://www.rockauto.com/RSS/vehiclefee ... &html=true
Gaskets are real cheap. :mrgreen:
1999 Dodge Ram 2500
DoctorC
Post #17 by DoctorC » Tue Sep 10, 2019 3:35 am
Well I fell for it! I was gonna order 3 and just went with 1, cuz 1 left!
Do these rubber ones need replacing like cork? Or is it a forever gasket?
bubba22349 wrote:From your other post on valve cover leak did you take any pictures of the valve cover flange area after you cleaned off the old gasket? :nod:
No I didn't =( Sorry. But the cover will off soon enough for a new gasket. I'll pic then.
I have the stang on front ramps with cardboard underneath. Today I happened to notice there is a puddle under the oil filter. I ran my hand on it and it was wet underneath. I think I musta done a piss poor job of installing it? I did notice that it seemed a little big (outer lip of can goes past rim of block) but Napa said it was the correct size...
I'll drain the oil and swap it out.
Weber 32/36,
MSD 6AL+MSD Coil,
Duraspark 2 dizzy
chad
Post #18 by chad » Tue Sep 10, 2019 8:55 am
"...on front ramps..."
makes it a lill more difficult 2C as
the path as it will B skewed a lill now.
C if there is another path (look up on block)
coming dwn frm elsewhere...Glad ur not runnin it
as the fan can blow the stream further obscuring location.
Drivn is even worse on ID as the additional air flow adds to difficulty.
Users browsing this forum: No registered users and 12 guests
