Howdy guys,
So i was reading about wrapping my headers and found thats a bad idea. So I'm looking into the ceramic coating stuff. Has anyone done this and what roughly should i expect to pay? And what companies do you recommend. I have the VI dual out headers.
Also, should i coat the down pipes too from the headers or just the headers?
Thanks guys
Ryan
<<< New Site Update >>>
Header Coating
- StarDiero75
- Registered User
Header Coating
--1965 Ranchero w/1966 200, dual friction diaphram 9" Modern Driveline clutch and billet flywheel all balanced, 1985 SVO WC T5 with front shift, 1966 2.8 Ford 8", Weber 32/26 with VI adapter, CRT Performance HEI.
- Pete62SOHC
- Registered User
Re: Header Coating
Most places will usually get anywhere from $150.00 - $200.00 for ceramic coating a header. Most powder coating facilities offer ceramic exhaust coatings these days, which means you can probably have it done locally instead of shipping your header somewhere. A quick Google search shows a couple powder coating facilities in or near Bremerton:
1.) MAD Custom Coating 844-623-4897
2.) Global Coatings LLC 360-479-0694
Ceramic coating any of the other exhaust components is never a bad idea, but isn't absolutely necessary unless you're looking for the ultimate in heat management relative to how much the exhaust might heat the floors of the car and passenger compartment. Quality insulation under the carpet will usually take care of that job, though.
1962 Ford Fairlane / 170/3-spd. originally / Ford AU 4.0L Intech SOHC & Hughes Powerglide swap in process / Haltech EFI / Borg Warner billet 82mm turbocharger / SN95 8.8 rear axle / 4-wheel manual disc brakes
Re: Header Coating
Howdy Ryan:
I think coating header is a good idea. Your header is likely one of the most expensive pieces on your engine. Especially if you are in a high rust area. I had mine coated by HPC, both inside and out. I had to ship to them. They were south of SLC. They were the only source back then.
Test fit your header for clearance. I didn't and had to redo a section down by the starter.
Keep us posted on your progress.
- woodbutcher
- VIP Member
Re: Header Coating
Good luck.have fun.Be safe.
Leo
Otto von Bismarck
Otto von Bismarck
- chad
- Registered User
Header Coating
...mmmphy...?
Wonder Y the 'pipes' on my bike have lasted 40 yrs. SS, nice'n blue up by the heads, beautiful rainbow as they come down, that shinny SS back to the muffs? Can't tell U bout the inside as I haven't been off in a decade...
Re: Header Coating
chad wrote:...mmmphy...?
Chad, they were chrome plated. Must have been quality to last that long.
I had a set of Hookers done by Jet-Hot. The photo shows them when new & they have dulled over the years, but are still coated, with no rust.
- chad
- Registered User
Header Coating
hope OP has what he needs...
I've heard of ceramic. There is 'chrome-lookin" in that material (like ur long tubes)?
R those coated similarly inside or does the inside havea different look?
Wish I hada set like that but probably would need major mods to fit the bronk...
- StarDiero75
- Registered User
Re: Header Coating
I'm actually gonna drive by MAD here on Monday. I got busy dropping my head off at the machine shop today.
It says on their site they do header ceramic coating so we'll see the price tag for that. I'll probably end up doing inside and out. I want these headers to last forever. Do it right the 1st time lol.
I probably wont do the downpipes, just the headers since its not really necessary.
Thanks for the input guys, keep it coming with info
Re: Header Coating
Do the down pipes, since they are visible & subject to rust.
Users browsing this forum: No registered users and 10 guests
