Sleeving a 200
Matthew68
Sleeving a 200
Post #1 by Matthew68 » Thu Aug 08, 2019 1:59 pm
I just got a call from my machinist who has disassembled and assessed my 68 200 block. Cylinder #1 has a lot of ring damage that will necessitate either:
1. Overbore of 60 thou (30 for the other cylinders)
2. Overbore of 30 thou plus a sleeve for #1
He said it's also possible #6 will need a sleeve, but they won't know for sure until they bore.
Thoughts on sleeving? It’s fairly cost effective ($105/each). I can’t find any blocks near me for that price and even if I did there’s no guarantee that one won’t have issues. Plus I would be in more labor for disassembly and cleaning.
1968 Mustang Coupe 200ci - Pertronix + Coil
Gulfstream Aqua - Interior + Exterior
Re: Sleeving a 200
Post #2 by xctasy » Thu Aug 08, 2019 2:46 pm
dooo it. :P
wsa111
FSP Moderator
Re: Sleeving a 200
Post #3 by wsa111 » Thu Aug 08, 2019 3:55 pm
I agree with X. #1 cylinder is sometimes thin facing the water pump. Then .030" over pistons in all 6 cylinders.
67 mustang,C-4, with mod. 80 hd, custom 500 cfm carb with annular boosters, hooker headers, dual exh.-X pipe, flowmaster mufflers, DSII dist. MSD-6425CL & MSD-Blaster 8252 Coil. Engine 205" .030" over with offset ground crank & 1.65 roller rockers. 9.5 comp., Isky 262 cam.
chad
Sleeving a 200
Post #4 by chad » Thu Aug 08, 2019 5:07 pm
2X the 2 above ( smarter move, cheepest now) BUT...
get all the info U can & keep safe.
ie how thick is the sleeve, how much bored to insert, what co, differences in hone or pistons, etc?
I hada Subie in late 70s I heard wuz OEM an alu block w/steel sleeves, nuttin wrong wid da design !
or
may B no block'n just sleeves? (butter? paper?)...
:thumbup:
Chad - '70 LUEB on '77 frame (i.e. PS, D44, trapezoidal BB 9", 4.11), '69 250ci, NV 3550 & DSII, "T" D20/PTO, 2" SL, 1" BL, 4 discs, 33"X15", tool boxes, etc. Seeking: Hydraulic gear motor for Koenig pto. chrlsful@aol.com
Users browsing this forum: No registered users and 22 guests
