I've got four "weber" carbs. Two are actual webers and are a matched set that were on a Datsun. The other two are both (I think) Motorcraft that I acquired individually from.... somewhere.
Which one should I put on a stock-ish 200? I do like the second two as they have automatic chokes I can setup, but I should be able to unbolt those and put them on the Webers.
I can get a better pic of the tag on these if need be.
I don't see any identifying marks on this one.
