2018 Contributors:
yellow terra rocker arm install tips
rbohm
Assistant Admin
Post #1 by rbohm » Sun Aug 24, 2014 5:09 pm
When you install the yella-terra rocker arms you starve the distributor gear & camshaft gear of very needed lubrication.
To fix that condition the second & third lifters are on either side of the oil hole above the gears.
You can cut a .025" x .025" groove in those two lifters and that will flood the area with the necessary lubrication to prevent scoring of the gears.
http://i.imgur.com/eOBfvyU.jpg
Tech article by Bill Ambler billythedistributorman@live.com
64 falcon
66 mustang
05 grand marquis
transient nodes of thought
of invention
wsa111
FSP Moderator
Re: yellow terra rocker arms + DUI Upper Shaft Oiling
Post #2 by wsa111 » Thu Sep 25, 2014 9:03 pm
See my new tech article if running 1.65 yella-terra full roller rocker arms with a DUI distributor for extra distributor shaft oiling with extra gear oiling. billythedistributorman@live.com
XMFalcon221
Re: yellow terra rocker arm install tips
Post #3 by XMFalcon221 » Fri Jan 23, 2015 5:52 am
Hi Bill, do have a link for your new tech article for a DUI dizzy and yella terra rockers? Just want to make sure I'm reading the right thing. Cheers
cameljockey
Post #4 by cameljockey » Tue Feb 03, 2015 4:29 pm
I second the motion for the link to the Tech article lol :D
AHHHHH! My brain is itching!
