chrysler 6 ?
HOAGY
chrysler 6 ?
Post #1 by HOAGY » Sun Dec 14, 2003 6:22 am
hello i have a chr. 6 in a welder that i want to rebuild. where do i get parts etc? how do i know the age cid etc? thanks hoagy
addo
Post #2 by addo » Sun Dec 14, 2003 6:26 am
Well, you must have some idea "round about" what age it is?
Hot 6t Falcon
Chry 6
Post #3 by Hot 6t Falcon » Sun Dec 14, 2003 10:53 am
Are you talking about the flathead 6 or the newer OHV slant 6?
My brother had a '53 flathead 6 in a '47 plymouth coupe. MoPar made a factory dual carb intake manifold and a cast iron dual outlet exhaust for the Dodge Trucks back in the mid-fifties.
I know there is a Plymouth Club of America (based up here in the north land)
Good Luck
Dennis Schjeldahl, (say Shell-doll)
Co-Author of The Ford Falcon Performance Handbook
http://www.falcon6handbook.com
80broncoman
Post #4 by 80broncoman » Sun Dec 14, 2003 1:25 pm
I have heard that some flathead chrysler 6s were also sold by and namplated by continental. Don't know if this is one of them but it might be. Having two names to look under somtimes helps find old nos parts.
Jim
OAPSE Union Member
Real men don't wear Bowties
HOAGY
Post #5 by HOAGY » Sun Dec 14, 2003 8:51 pm
if this helps, the exhaust goes under and to the front thanks HOAGY
HOAGY
Post #6 by HOAGY » Sun Dec 14, 2003 8:54 pm
I THINK IT IS A 55 FLATHEAD THANKS HOAGY
Lazy JW
FSP Moderator
Post #7 by Lazy JW » Sun Dec 14, 2003 10:35 pm
Chrysler made a zillion of those for industrial engines. Most parts stores should be able to get what you need. Or try JC Whitney
Joe
"The White OX" 1974 F-350 300-6, Stock single exhaust, Carter YF, T-18A, Dana70 w/4.11, Flatbed dually w/dump bed. "Where no oxen are, the crib is clean, but much increase is by the strength of the ox" (Proverbs 14:4)
panic
Post #8 by panic » Wed Dec 24, 2003 9:44 am
Used in passenger cars and trucks through 1959, 230" is common, also used in big Smith's air compressors.
Hot 6t Falcon
Engine size
Post #9 by Hot 6t Falcon » Wed Dec 24, 2003 10:53 am
My brother's 47 ply w/'53 Chrysler "6" was a 265 CI. It had "Spitfire" cast into the head. Seems to me that the orginal engine had like 198 ci - but others would know for sure.
The Spitfire was also used in Dodge trucks - they came with a factory cast iton dual exhaust manifold and a cast iron dual one barrel intake. Both manifolds had Chrysler part numbers cast in.
It was a hoot to go to the drag strip and tell them it was a "Stock" engine. They ran us against Chevy Sixes for a while and then finally put use into the "gasser" class.
Hot 6t Falcon
Post #10 by Hot 6t Falcon » Wed Dec 24, 2003 11:14 am
The '47 Plymouth six was 218ci
Chrysler - 1954 - 264.5 cid
DeSoto - 1954 - 250.6 cid
Dodge - 1959 - 230 cid
Dodge Truck - 1968 - 250.6 cid*
Plymouth - 1957 - 230.2 cid
You can see the "Spit" but not the "fire"
Good Luck
Hemiman
Post #11 by Hemiman » Sat May 21, 2005 9:20 am
The 230 & 251 flat heads were used in Dodge Power Wagons from 1946-end of production, (1968 domestic, & 1978 export). The parts suppliers for these trucks will have all the parts you need. Try Vintage Power Wagons or Adirondack Dodge. There are many others too.
http://www.vintagepowerwagons.com/
http://www.adirondackdodgeparts.com/
