Rebuild problems, HELP!!!!!
McGoo
Post #1 by McGoo » Sat Sep 24, 2005 10:05 am
I'm hoping someone here can help me with a wee bit of a problem I'm having.
I took the engine & tranny out of my car to redo the front end. While it was out I thought it would be a great time to replace the front crank seal & oil pan gasket and add power steering to the car.
Everything went well, except for the reinstallation of the alternator .
I put the lower mounting bracket bak on the car in the only position that it can go on. Now the alternator pulley is about 1/2 a groove away from the inner pulley on the crank. It seems to be too far back!!! :shock: I am using the same crank pulley & alternator that came off the car!
I thought that maybe the damper wasn't back far enough on the engine, but it seems to be on as far as it can go, & it's pulley lines up with the water pump perfectly. The alternator also misses the top adjuster mount (lower part of P/S bracket) by the same amount.
Any help would be appreciated.
Thanx
Paul :beer:
addo
Post #2 by addo » Sat Sep 24, 2005 10:14 am
There's no cylindrical spacer that adjusts alternator position, like some engines have? That's about the only thing which springs to mind.
McGoo
Post #3 by McGoo » Sat Sep 24, 2005 10:34 am
Addo,
Thee is the usual spacer, but it is still in the same place as before. I even grabbed the original alternator to see it it would fit. No luck
I can't seem to see what went wrong, but it has to be something simple.
I must be having a grey moment.
Paul
Users browsing this forum: No registered users and 5 guests
