Hello, I have purchased a Toro Golf Course Tractor that has, what I believe to be, a Ford 6 cylinder engine. I'd like some help identifying the motor if possible. The numbers I got from the casting on the bottom of the engine are possibly 76 5 EBP-6U15. Not 100% sure that's what it says but maybe. It is running, but won't go in gear. I'd like to get the specs/id on the motor and to find out what I should do to the motor first (change oil, filter, etc.).
