Turbo 240 or 300
pmuller9
Re: Turbo 240 or 300
Post #101 by pmuller9 » Sun Apr 02, 2017 3:41 am
I don't have an lower EFI manifold here to measure.
What is the ID of the injector holes in the intake manifold?
Ramian17
Post #102 by Ramian17 » Sun Apr 02, 2017 4:34 pm
I won't lie to ya I don't know which # ids the injectors.
Ramian17
Post #103 by Ramian17 » Sun Apr 02, 2017 4:45 pm
So what do you think can I cut it all the way to where I'm pointing pretty much all the way up to that support that connects them? Then weld on flanges or straight to plenum?
pmuller9
Post #104 by pmuller9 » Sun Apr 02, 2017 6:49 pm
I apologize, I wasn't thinking when I wrote ID.
I meant to say the Inside Diameter of the hole for the injector. LOL
It should be around 14mm
You just need to make sure there will be room to install the injectors and fuel rail.
There are shorter injectors available.
These are the ones I was looking at. Amazon has them for $339
The prices listed are for all six injectors.
https://www.summitracing.com/parts/dwk-16u0000426
I visited their booth at the PRI trade show.
They do a great job of flow matching the injectors plus the spray pattern is better than most which will help at idle and low rpm.
Ramian17
Post #105 by Ramian17 » Sun Apr 02, 2017 8:01 pm
Woo hoo 339 each yeah get some. Those shorties are the ones I need for sure. I love them that will be more than the turbo for all six of them lol. Will that fuel rail company drill holes in them or will I have to do that?
Ramian17
Post #106 by Ramian17 » Sun Apr 02, 2017 8:02 pm
Wait is it 339 for 6?
pmuller9
Post #107 by pmuller9 » Sun Apr 02, 2017 9:19 pm
Ramian17 wrote:Wait is it 339 for 6?
You did not read my post carefully enough where I stated that the listed prices were for six injectors.
You must have gone into shock before you got that far. LOL
I should have made that part clear before I said anything about price.
Anyway back to my original question.
What is the inside diameter of the hole in the intake manifold for the injector?
Ramian17
Post #108 by Ramian17 » Mon Apr 03, 2017 9:54 pm
As best I can measure it's 10.79mm or .4242 inches. According to the caliper.
Ramian17
Post #109 by Ramian17 » Mon Apr 03, 2017 9:59 pm
I looked all over and I can't tell if they will fit my manifold? I really hope they do there shortlyness is going to be key in the goal of no modification to the dog house.
pmuller9
Post #110 by pmuller9 » Mon Apr 03, 2017 10:39 pm
Ramian17 wrote:I looked all over and I can't tell if they will fit my manifold? I really hope they do there shortlyness is going to be key in the goal of no modification to the dog house.
Here is the mounting instructions.
Looks like the injectors need a 13.57 mm hole both top and bottom. (Page 5)
http://www.bosch-motorsport.com/media/c ... 867pdf.pdf
Ramian17 wrote:As best I can measure it's 10.79mm or .4242 inches. According to the caliper.
That should be the small exit hole for the injector tip.
Measure the larger hole that the injector "O" ring slides into.
Ramian17
Post #111 by Ramian17 » Tue Apr 04, 2017 12:48 am
Yep the bigger hole on the outside is 13.57. perfect
Ramian17
Post #112 by Ramian17 » Tue Apr 04, 2017 12:53 am
Can I use the stock fuel rail with those and if so do you know where I can get a stoke one? If I can't get a stock one will those custom fuel rails you showed me need machining?
pmuller9
Post #113 by pmuller9 » Tue Apr 04, 2017 1:35 am
A stock fuel rail will have the correct spacing and should have the right holes sizes for the injectors.
The only question is if the stock rail is big enough to flow the extra fuel volume.
I would go to a Pull and Save salvage yard and get a stock 4.9 rail from a Ford truck or van.
Ramian17
Post #114 by Ramian17 » Tue Apr 04, 2017 1:50 am
Do you think it will for enough? I honestly have no idea. I'll use the custom rails you showed me if you think it can be done without super crazy fabrication? Lol
pmuller9
Post #115 by pmuller9 » Tue Apr 04, 2017 9:25 pm
Ramian17 wrote:Do you think it will for enough? I honestly have no idea. I'll use the custom rails you showed me if you think it can be done without super crazy fabrication? Lol
No super crazy fabrication.
The hole drilling in the rail for the injectors is best done on a mill where the rail can be clamped to the movable deck.
The rail ends get threaded for 6an fittings.
The part where you get creative is the two (or three) rail mounts that come up from the intake manifold.
The mounts should come up at an angle in contact with the side of the rail with bolts running through the lower part of the rail into threaded holes in the mount.
Ramian17
Post #116 by Ramian17 » Tue Apr 04, 2017 10:23 pm
Nice that doesn't sound too bad. I would love some picks of a stock set up our even a sweet aftermarket set up? So I see the mounts screw into the manifold, and you're saying that the mounts bolt to the rail?
pmuller9
Post #117 by pmuller9 » Mon Apr 10, 2017 2:49 am
The bosses with the holes that are threaded will be in the wrong location for the short injector.
Grind them off for appearance sake.
First get the new short injectors.
Drill the rail stock to fit the injectors.
Install injectors #1, #3, #4 #6 with the rail onto the intake manifold.
Make two brackets (chunks of aluminum) that bolt to the side of the rail and extends down to intake runners #2 and #5.
The brackets need to be wide enough so the 2 mounting screws straddle the holes for injectors #2 and #5 in the rail.
Curve and angle the brackets other end so it fits the curve of the intake runner and weld them to runners #2 and #5.
Did you get the new turbocharger?
Ramian17
Post #118 by Ramian17 » Mon Apr 10, 2017 4:30 pm
Wooooo hooooo it just came in today!!!! She is beautiful!! I'm acting like a crazy school girl right now!!!! So excited. I hat doesn't sound to bad I should be able to pull that off. Still waiting on pistons though..... :(
pmuller9
Post #119 by pmuller9 » Mon Apr 10, 2017 4:53 pm
A Thing of Beauty!!
Can you spin the compressor blades by blowing into the compressor inlet?
Which pistons are on order?
What did you end up with for connecting rods?
Did you order a custom cam from Crower?
I Know, A lot of questions but this is exciting?
Ramian17
Post #120 by Ramian17 » Mon Apr 10, 2017 6:59 pm
Yep she spins real nice. Not sure where the pistons came from I'll ask the mechanic. But they actually did come in today!!!! He now has everything and will be putting her together this week. Yeeeee haaaaaa!!!! I just went over there and they are super pretty looking!! The rods are forged Chevy rods. I'm pretty sure he used a local cam guy here in Redding but I'll ask about that too. It's definitely a custom ground cam to the specs we talked about earlier. It's all good keep'm coming you've answered way more questions than I have lol. Tell me about it I'm so excited I want my van back real bad!!!!!!!
Soldmy66
Post #121 by Soldmy66 » Mon Apr 10, 2017 8:03 pm
I noticed that you celebrated receiving your new turbo by having some delicious hummus.
Good call.
sthorvictor
Post #122 by sthorvictor » Mon Apr 10, 2017 11:16 pm
sorry its been awhile just came across this, subscribing! loads of work and exciting progress, curious on the pistons as well! :thumbup:
Best of luck,
Seth
turbocharged maf 300 f150
pmuller9
Post #123 by pmuller9 » Tue Apr 11, 2017 4:56 am
We must have pictures of rods and pistons please!
Ramian17
Post #124 by Ramian17 » Tue Apr 11, 2017 11:19 am
Haha copy that I'll get some pics today.
Ramian17
Post #125 by Ramian17 » Tue Apr 11, 2017 2:37 pm
Icon pistons and scat rods. He was pretty excited on them he seemed to think that is is going to be a total one off and one heck of a mean machine!!!! I told him that other people have turboed this motor but that u had never seen in a 1966 Econoline lol.
pmuller9
Post #126 by pmuller9 » Tue Apr 11, 2017 3:18 pm
I'm Curious?
Those are Scat Pro Stock "I" beam rods.
The Scat 6125 "I" beam Chevy small block rod doesn't show as being available in the Pro Stock series.
Plus the SBC rods have a .940" Bid End width which is smaller than the Ford 300 .994" BE width.
The Scat 6215 Jeep rods have a larger BE width that can be cut down to the Ford 300 BE width.
The Big Bock Chevy rod BE is .992" and can be made with the smaller 2.100" rod journal to work on the Ford 300 crank.
Just wondering what rods those are or did your machinist have custom rods made?
Ramian17
Post #127 by Ramian17 » Tue Apr 11, 2017 3:49 pm
I'm not sure but I will ask him that too. This may be a stupid question but will they not work if the BE width isn't correct? What do you think if the pistons? The mechanic was super excited on the Pistons talked them up real good.
pmuller9
Post #128 by pmuller9 » Tue Apr 11, 2017 4:03 pm
Ramian17 wrote:I'm not sure but I will ask him that too. This may be a stupid question but will they not work if the BE width isn't correct? What do you think if the pistons? The mechanic was super excited on the Pistons talked them up real good.
The pistons are perfect with the top ceramic thermal coating and the skirt coatings.
The rod BE width with the proper clearance to the crank rod journal width keeps the rods small end centered in the piston and controls oil coming out from the rod bearings on the crank. The clearance is around .015"
You certainly don't want the rod walking side to side any distance on the crank journal
Ramian17
Post #129 by Ramian17 » Tue Apr 11, 2017 4:49 pm
Yeah I figured the wrong size wouldn't be good. That makes me so happy that you like the pistons though.
PLand1
Post #130 by PLand1 » Mon May 08, 2017 7:51 pm
Glad to see another Econoline! I have a second gen E100 and I've been thinking about doing this exact same thing for the past year. I haven't really had the time or money to initiate it though. There is a tone of information on this thread that will help me when I do though.
I'm not as committed to keeping the doghouse unmodified (although it would be nice). My idea was actually to use one of those throttle body injection kits on an offenhauser 4 barrel intake and just do a blow through set up. Something like this:
http://fitechefi.com/products/30004/
Do you happen to have the specifications on what was done to your motor? I'm just trying to make a list so that I can start budgeting.
Also, are you using a manual or automatic transmission? And I know y'all were talking about different ignition setups, but I was just thinking of staying with my Pertronix ignition that I installed and just upgrading to an msd blaster coil or something similar. Any thoughts? And how is your progress coming along??
pmuller9
Post #131 by pmuller9 » Mon May 15, 2017 10:33 pm
Updates?
Ramian17
Post #132 by Ramian17 » Tue Jun 13, 2017 2:43 am
So I finally got my engine block. It has a steel crank, forged rods, forged pistons, roller rockers, hydraulic lifters, custom ground cam, hardened valves, valve seats, and push rods on exuast and intake $$$$$$$$$ I need to install the high flow oil pump which i read isn't that easy. Any advice is always welcome, I don't honestly know but I think I need to get a custom harmonic balancer made, if yes where? I also need a gear to go on the balancer. Can I use all stock 300 parts from a 1990s fuel injected truck for that? Then it will be alternator, high flow water pump and I think that's it. Then off to the master welder for custom header and fuel injected intake. With a turbo attached all under a stock looking dog house!!!!!! Yeeeee haaaaaa
Ramian17
Post #133 by Ramian17 » Tue Jun 13, 2017 2:44 am
PLand1
Post #134 by PLand1 » Tue Jun 13, 2017 6:18 am
You shouldn't need a custom harmonic balancer. That's it in the box in the lower pick. These six cylinders are balanced well enough that they don't have the big ones like on the v8s. Your engine builder should have balanced your motor too I would think. Did you ever figure out what pistons and rods you used?
Ramian17
Post #135 by Ramian17 » Tue Jun 13, 2017 3:06 pm
Gotcha yeah I thought that he was going to put the oil pump and the balancer on. I was kinda up set that they weren't on there. I was just so happy to be able to go pick it up. It has been there since the beginning of December. So do I need to take it to a shop and have the balancer put on and balanced? Does the gear for the crank sensor just bolt on the balancer? Can I use a stock gear or do I need a custom one made for my application. Also the balancer I have is from a 240 is that going to matter now that its a 300? They are scat rods and icon pistons. Both forged.
Ramian17
Post #136 by Ramian17 » Sun Jun 18, 2017 1:15 am
Where can I find a nice and tall valve cover for a 240? Needs to fit over roller rockers. I had some cheap chrome valve cover on that was actually hitting the stock rockers that where in there.
pmuller9
Post #137 by pmuller9 » Sun Jun 18, 2017 2:01 pm
I have a Clifford valve cover for sale.
https://www.dropbox.com/s/9fqcb693hbxqe ... 1.JPG?dl=0
Ramian17
Post #138 by Ramian17 » Wed Jun 21, 2017 12:37 am
Perfect I want it, how much you want for it? Is it taller than stock? Or taller than the cheap tin chrome valve cover you can get for these motors? Do you know if it will clear roller rockers? Any advice on the high volume oil pump installation? Do you know if I will need a crank sensor aka a gear on the harmonic balancer? Or will a cam sensor be enough? Sorry for the 20 questions game.
Ramian17
Post #139 by Ramian17 » Thu Jul 13, 2017 4:24 pm
So it's official she is %100 ready to go back into the van. Just gotta get some buddies together to help. Does anyone know if both the holes on the driver side that are being pointed at in this pic have oil pressure going to them? I know the hole on the right with a fitting in it, was the oil pressure sensor sender location.
Also does anyone know if the upper rear hole that is being pointed at in this pic has coolant being pumped to it? I know that the lower hole with the fitting is the old location for the temp sensor sender.
I'm trying to figure out my oil and coolant supply for the turbo. Any ideas?
Post #140 by bubba22349 » Thu Jul 13, 2017 11:12 pm
The two small holes below the blocks side cover go into the block oil passages and will have oil pressure. Look at were your oil pressure senders wire it's white with red stripe is closest to one of those oil passage holes and install the oil pressure sender there you can plug off the other one or use as oil supply for the Turbo. Did you already make an oil return fitting in your oil pan or the lower part of the block for the Turbo drain?
In the bottom picture the larger hole just below the head and at the rear is were your coolant tempature sender is installed the other hole can be plugged off or used as coolant supply for the turbo. Good luck :nod:
Ramian17
Post #141 by Ramian17 » Fri Jul 14, 2017 1:19 am
Awesome thanks bubba22349. What do you think should I use one of those coolant holes for the turbo or tap into one of the coolant hoses? Haha my van had it totally opposite. The rear oil hole had the guage sender plugged into it, and the lower coolant hole had the guage sender plugged into that. The other holes must have been plugged. As long as you are correct that will make the turbo installation way easier. No I haven't put a return hole into the oil pan Im going to wait until the turbo is mounted before I go for that.
pmuller9
Post #142 by pmuller9 » Thu Aug 24, 2017 3:34 pm
Any Updates?
Ramian17
Post #143 by Ramian17 » Fri Aug 25, 2017 10:24 am
Yeah slowly but surely I am making progress. Just two nights ago we got the motor put back in. Now it's over to my buddies to help me weld the header as soon as I have some free time to get it over there. I'm thinking I'm going to go with bull dog for the engine management system? What do you guys think? Has any one used there products?
pmuller9
Post #144 by pmuller9 » Fri Aug 25, 2017 12:03 pm
Thanks for the update.
Nice to have a crew that can muscle the engine in and out of the van.
I'm interested in watching the header construction.
Can't find any specific information on "Bull Dog" or "Bully Dog" systems.
Do you have a good link that has a breakdown on system features or specifications?
Ramian17
Post #145 by Ramian17 » Wed Oct 04, 2017 1:58 am
So my busy season is starting to whined down. I've got the motor all the way back in, the dog house somewhat back on, and the new steering box all welded in and fully hooked up!!! We were in the process of building the header and we decided that it would be smart to build the intake first and then header. So my first question is if you guys remember the stock lower half of a 300 intake that I'm going to use to make a plenum, how big of a throttle body should I go with? Which translates to how big of a tube should I use? Then should I tapper it as it goes back to the rear of the motor? Pmuller you said a stock 300 is equivalent to 60mm but should I go bigger for this application? My first step is buy the throttle body. Then decide what tubing thickness I should use? Also for the header planning I have talked to lots of turbo header guys and it is looking like my best option is going to be to build the header so that all the exhaust is ran up front to the turbo. Which makes the header pass right by a bunch of bolt holes in the front of the block (probably for AC and power steering). Should I weld a bracket to the header there for extra reinforcement that will bolt to the AC or steering holes? Then I've been told by different guys to go with either stainless steel tubing, or schedule 40 stainless steel pipe. The pipe being way stronger and thicker. The guys that said to go with schedule 40 said that I wouldn't even need the bracket bolted to the motor. So what do I do? what's over kill and what's not lol. I want this to be super strong and never break lots of off roadin and hard bouncing!!! I rally the old girl!!! What do ya think? Haha sorry lots of question. Pmuller I talked to bully bog and turns out my buddy that turned me onto them was mistaken they do not make something for my application. So after all my research it's looking like megasquirt is what everyone points me too. Someone just told me about a screen you can get that would wire in so I can have full control and tunability right there will I drive. Which is really what I wanted. So from reading on here it looks like you guys have figured out the megasquirt with a turbo so I should be able to just plug in some numbers and she'll fire right up??? lol?? Shewwwy I think that's it thanks for all your guys help. Hopefully more progress and updates soon!!!!!
pmuller9
Post #146 by pmuller9 » Wed Oct 04, 2017 11:19 pm
I wouldn't use more than a high flow 65mm throttle body since the focus is mainly on low to mid rpm power.
The only drawback of using a larger throttle body is that it makes for a touchy low rpm throttle response.
I would leave the plenum dimensions the same as it travels back so each cylinder "Gulps" from the same plenum volume.
The forward bolt holes on that side of the block is usually for the alternator bracket.
For a turbocharger header that operates at a much higher temp than a regular header it is recommended that 321 stainless steel be used rather than 304.
PIPE and TUBING sizes are not the same and tubing sizes are offered in smaller increments than pipe.
SS Tubing can be purchased in a wide range of wall thicknesses so no need to go to schedule 40 pipe sizes for the sake of thick walls.
Use the MegaSquirt-3
Ramian17
Post #147 by Ramian17 » Wed Oct 04, 2017 11:56 pm
Cool thanks again pmuller. I honestly know very little about the engineering side of this. So exact numbers are awesome. Should I go 60 or 65mm? How thick of aluminum tubing for the plenum and how thick of stainless for the header? Then should I match the inner diameter of the header tubes to my old headers? My alternator is on the drivers side of the motor. I have a set of four lower and a set of three upper holes on the passenger front of the motor. I was going to use one of them for the crank sensor.
pmuller9
Post #148 by pmuller9 » Thu Oct 05, 2017 12:39 am
I would go 65 on the throttle body.
The aluminum can be around .125" wall.
The stainless steel thickness for the header depends on what thickness your fabricator can mandrel bend.
.120" wall would be nice.
Off the shelf mandrel bend tubing is 16 gauge or around .065"
Ramian17
Post #149 by Ramian17 » Thu Oct 05, 2017 1:14 am
Nice ill see what I can find on mandrel bends that thick. Any suggestions on which company or what throttle body to use there seems to be a ton out there.
pmuller9
Post #150 by pmuller9 » Thu Oct 05, 2017 6:00 pm
BBK 1517
Return to “Turbo, Supercharger, and Nitrous”
Users browsing this forum: pmuller9, thatblue_67stang and 3 guests
