Engine vibration (torque bars)
thatblue_67stang
Post #1 by thatblue_67stang » Thu Oct 04, 2018 10:56 pm
I beat the living doggie doo out of my turbo engine. It's just fun to do. Flying down the highway at 70mph and boosting up to 100mph. I have a bunch if extra components that just go along with having a turbo. I was wondering if anyone had any recommendations for torque bars to attach to the engine then the frame to help keep the engine in place to stop rattling snd also wear and tear.
Brayton
1967 Ford Mustang Coupe
200 Inline 6 Turbo Charged
Image Image
brandoncw
Re: Engine vibration (torque bars)
Post #2 by brandoncw » Fri Oct 05, 2018 8:27 am
box in the sub frame some and get or make solid/stiffer engine mounts?
Skilled labor isn't cheap, Cheap labor isn't skilled.
thatblue_67stang
Post #3 by thatblue_67stang » Fri Oct 05, 2018 5:06 pm
brandoncw wrote:box in the sub frame some and get or make solid/stiffer engine mounts?
i basically daily drive the car and its almost time to put it away so dont want to get into any big project
Brayton
Image Image
Post #4 by bubba22349 » Fri Oct 05, 2018 7:16 pm
A quick down and dirty way to do a strap for the engine is to use a piece of cable or chain. Good luck :thumbup: :nod:
powerband
FSP Moderator
Post #5 by powerband » Fri Oct 05, 2018 8:01 pm
I like the simplicity of the wire cable idea ...
Some motor mounts have interlocking plates allowing only limited movement on the bonded rubber halves before they catch. The '74 Maverick with supercharged 250 has OEM (I believe) motor mounts that interlock. Got new replacement mounts when I swapped engine but new version did not use same interlock plates so I re-used originals ...
The '61 250 (NA) uses Grade #8 bolts with locking nuts loosely thru the original type motor mount plates / rubber to limit movement.
thatblue_67stang
Post #6 by thatblue_67stang » Fri Oct 05, 2018 10:22 pm
powerband wrote:A quick down and dirty way to do a strap for the engine is to use a piece of cable or chain.
i was thinking of making something like a big splitter rod. A heim joint on each side and an adjustable rod in the middle and attach it to the engine and to the frame. I would not attach it to the same places this one is but this is just an example.
Brayton
Image Image
fakundo__92
Post #7 by fakundo__92 » Fri Oct 05, 2018 11:52 pm
mmm I think it transmits the vibrations to the chassis, but it can work. Elastomer motor mounts are used on these sides, like these.
I have you on instagram haha. very cute your mustang
thatblue_67stang
Post #8 by thatblue_67stang » Sat Oct 06, 2018 3:19 pm
fakundo__92 wrote:mmm I think it transmits the vibrations to the chassis, but it can work. Elastomer motor mounts are used on these sides, like these.
thanks for following me. my mustang has never been called cute before haha. there is a first for everything
Brayton
Image Image
sdiesel
Post #9 by sdiesel » Tue Dec 04, 2018 8:24 am
on my truck(s)
I use a standard turnbuckle.
it's ugly but effective.
furthermore, I brace the transfer case which is affixed to the rear of tge transmission.
in this manner it helps solidify the entire unit.
relieving strain on any one part of the system
fast64ranchero
Post #10 by fast64ranchero » Tue Dec 04, 2018 10:00 am
[quote=The '61 250 (NA) uses Grade #8 bolts with locking nuts loosely thru the original type motor mount plates / rubber to limit movement. have fun[/quote]
This works very well and creates zero vibration if you leave the bolt loose.
63 Ranchero,1965 Mercury Comet Convert V-8, 1978 Fairmont small six, mill'd off intake, 62-1 ET 12.332 @ 123.49 mph (gone)
Users browsing this forum: No registered users and 5 guests
