 Not having any experience with turbos,maybe this is not germain to the subject.But here goes.Found a dipstick tube that threads into a fitting on the oil pan.Could you cut the female part out of a junk oil pan and weld it into the pan on your engine where you want the return line,and connect the return line from the turbo to that?Would make it very easy to do an R&R
 Not having any experience with turbos,maybe this is not germain to the subject.But here goes.Found a dipstick tube that threads into a fitting on the oil pan.Could you cut the female part out of a junk oil pan and weld it into the pan on your engine where you want the return line,and connect the return line from the turbo to that?Would make it very easy to do an R&Ron the unit if necessary.
Good luck.Have fun.Be safe.
Leo
