Reportedly there was a turbo kit marketed that used two head gaskets to lower OEM CR to turbo - usable levels along with other proprietary parts.
Interested in any experience lowering CR with thicker head gaskets. Could two gaskets survive a low boost setup?. Playing with CR calculator, the typical composite gasket crush thickness of @ .050 when doubled to @ .100" lowers typical CR @ full point. (.. or two composites with OEM steel shim head gasket between them?)
related info appreciated , and also somewhat opinions . 8)
NA engines would degrade chamber/quench design but with turbo ?.
thanks
thanks
