fast64ranchero
I'm building a new setup for my 63 ranchero. The current setup was in it when I got the car. (200 with big dish pistons and 250 2V head. Clay Smith 274H cam) the rings never seated and it is way under compressed for the head/cam setup. My new setup is zero decked flat top pistons to bring the compression up and the head is going to Wes King for porting, I'll figure final compression based on cam choice and deck the head to reach correct compression. Any of you guys have experience with solid cams like Clay Smith's 278 grind on 108 LC? I plan on calling CS to see what George would recommend but figured I ask here to see if any of you guys have had good results from another cam with "like" specs. Thx.
