distributor. final ignition time
fakundo__92
Post #1 by fakundo__92 » Tue Oct 23, 2018 11:23 pm
Hi. I have a 221 with 10.1 rc ... what would be the final ignition time that I have to use? Is there an equation?
chad
Argie motor timing
Post #2 by chad » Wed Oct 24, 2018 12:41 am
I know it sez "Aussie" on the index page & we get plenty guys from Oz on there but -
if U look closer the title sez "and South of the Border" too.
https://fordsix.com/viewforum.php?f=3
You may have better luck w/a greater percent of ppl who look at that forum who can answ this Q.
We DO have more volumn of viewers here, tho - just probably less knowledge of the Argie motor.
And that is what ur Q is abt, no?
So I would suggest U post the Q there AND use "Argie timing" in the title line.
(may B even the title I used above - 4 this post)?i
pmuller9
Re: distributor. final ignition time
Post #3 by pmuller9 » Wed Oct 24, 2018 11:20 am
You have a Dynamic Compression ratio around 8.2
I would think that a total timing of 34 degrees BTDC would be good
The one way to know for sure would be to tune your engine using either an engine dyno or a chassis dyno.
Please delete the rest of your duplicate post with this same title. "distributor. final ignition time"
rbohm
Assistant Admin
Post #4 by rbohm » Wed Oct 24, 2018 12:00 pm
you could possibly create ad equation that would tell you what initial timing, total timing, and what ignition curve you need, but there are many more factors to take into account than just compression ratio, cam timing, combustion chamber shape, intake and exhaust efficiency, even things like the shape of the piston dome are among the things you need to consider.
as you can see this is why we often use general rules of thumbs to start with and tune from there. generally i suggest running between 10-14 degrees initial timing with a total timing of 32-28 degrees, again depending on what the engine wants. you also need to determine how quickly the timing needs to come in, and when it is all in.
dyno tuning is the best way to do this, the next best way is to get out on the track and run the car hard and find the best lap times, just remember to be consistent with your driving to avoid that being a factor.
64 falcon
66 mustang
05 grand marquis
transient nodes of thought
of invention
wsa111
FSP Moderator
Post #5 by wsa111 » Thu Oct 25, 2018 8:34 pm
What are the specs on your camshaft??
What is your cranking compression. When doing this make sure the throttle is wide open.
67 mustang,C-4, with mod. 80 hd, custom 500 cfm carb with annular boosters, hooker headers, dual exh.-X pipe, flowmaster mufflers, DSII dist. MSD-6425CL & MSD-Blaster 8252 Coil. Engine 205" .030" over with offset ground crank & 1.65 roller rockers. 9.5 comp., Isky 262 cam.
Charlie Cheap
Post #6 by Charlie Cheap » Thu Dec 06, 2018 8:35 am
YES, there is a formula for just about every motor situation, but you need to know when the intake valve closes for accurate dynamic compression, static compression, rod length, deck height, volume of any dish/eyebrow cuts in pistons and head gasket piston diameter, plus the crush-height of the head gasket. Go to Physics Forum online and look at Mechanical Automotive questions.
