2018 Contributors:
Update - current batch of aluminum cylinder heads
62Ranchero200
Post #1 by 62Ranchero200 » Wed Apr 03, 2013 1:01 pm
Greeting Ford Six Fans,
I spoke with Mike yesterday and the final assembly is being done on the current batch of aluminum cylinder heads, which should ship some time this month, give or take porting or other custom mods being done.
Mike tells me that the combustion chambers are 55 cc, and can only be sized +- about 1 cc (54 - 56 cc) without altering the flow characteristics. I plan to leave mine at 55 cc.
Start your CR calculations!
Thank you,
Bob the Builder
62 Ranchero, 252 cid, 300 rods, RaceTek pstns, ARP mains bolts & studs, balanced & blueprinted, CI AL head, 1.6 adj rckrs, Smith Bros, 274/274/108 cam, CI int, Holley 500, DSII, CI SS hdrs, PowerMaster strtr and 1wire alt, Optima, V8 rad, T-5z, 10" organic clutch, 5 lug 8" w/3.80 Trac Loc, rear drums, front 5 lug discs, Centerlines. Next: ?.
