What to use for intake gasket
65-coupe
Post #1 by 65-coupe » Wed Oct 30, 2013 5:38 pm
What are you using for your intake gasket? Make you own or use a sealer.
1965 Mustang coupe, Poppy red with black interior, I6, DUI, CI alum head ported, 264/264 110 Clay Smith cam, 1.65 roller rockers, Autolite 2100 300CFM, Lokar pedals and throttle calbe, Spectre air intake. Shelby mod to front suspension, CI headers stainless with Jet-Hot ceramic coating, CI Stainless 2" impostor dual exhaust, 17x8 Coys C-67 wheels,
170-3tree
Re: What to use for intake gasket
Post #2 by 170-3tree » Thu Oct 31, 2013 9:29 am
I cut out one from some thick gasket paper then sprayed coper coat on it
63 Fairlane Sedan, 200 bored .030 over. Aluminium head. Autolite 2100 1.08. DUI ignition. 274/274-112* Hyd. 9.5:1 compression. ARP bottom end. 2.77 3 on the tree(until she blows I guess) 8 inch 3.55 rear 5 lug all standard on fairlane.
2010 Mazda 3s 2.5l L4 6spd manual
1957 Chevy Belair 4dr post, 283/powerglide
Inline6Merc
Post #3 by Inline6Merc » Thu Oct 31, 2013 8:25 pm
Cometic Gaskets Part Number: IR988059F(Front) and IR989059F(Rear)
64 Mercury Comet 204c.i.
DUI Ignition
Clifford dual out headers
10.2 to 1 Compression
CI Aluminum Head/Intake Manifold
480cfm Autolite 4 bbl
278 Solid Lifter Cam
1.6 ratio Roller Rockers
2500 Stall Converter
C4 Transmission
3.50gears
8inch Rear End
