mostly_broncos
I have a truck that im parting out and it has mass air injection. I had planned to sell the brain and the whole harness along with the MAF sensor and air box hoses and everything that would be needed to convert an older truck to mass air.
Being mostly a 351w guy I was surprised to see that it has a crank sensor and a special pulley/damper that goes with it as well as a special front cover where the sensor mounts. If I'm going to sell it as a kit then I think the front cover and damper need to go with it
I'd heard that 96's were OBD-II which makes it less desirable I think as a swap donor but I can't find an OBD-II connector. If it is OBD-II shouldnt they have a connector under the steering wheel? or were they located somewhere else in 96.
The part number on the computer is an F6TF-12A650-ED and it has a lot more pins than what you'd expect from an EEC-IV processor .
