thesameguy
I've got my old 170 sitting on the ground, and a new-to-me 200 sitting a little further away on the ground. I've got Pertronix on my old LoM 1/4" drive distributor, and points on the new LoM 5/16" drive distributor. I've got a recently rebuild Holley 1904 on the old motor, and an unknown (but reputed good) Holley 1940 sans SCV on the new motor. What to do...
1. My Holley 1904 onto the new motor, and move my Pertronix to the new distributor. That gives me a carb-> distributor / SCV -> LoM match for about $0.
2. Buy a '68+ distributor and a new Pertronix module and use the existing non-SCV carb. That's a non-SCV / conventional distributor match for somewhere between $100 and $150 depending on whether the distributor is used or new.
3. Invest in a DSII ignition conversion. That's somewhere between $100 and $300, depending on where the DSII parts come from (junkyard, rockauto, Classic Inlines, etc.)
4. Move to new tech: Ford EDIS-6 run from a Megajolt controller. That's about $300-$350, it seems - $150 for the MJ, $50-$100 for the EDIS parts, and then about $100 for the trigger wheel setup.
I am really leaning to #4 - a fully programmable ignition system for not much more than a CI DSII setup sounds pretty cool to me. It wouldn't look anything approaching period, but IMO not much worse than a big ol' DSII dizzy and some electronics hanging off it.
That leads me to these questions:
1. Will the single-belt crank pulley from my '62 170 fit on the '67/'68 200? It has a dual-belt pulley on it now, but has a single-belt alternator conversion so one pulley is doing nothing anyway. My single-belt crank pulley is six months old, in perfect shape. Losing that extra depth makes room for a trigger wheel.
2. Related, does anyone make or was there ever available a single-belt water pump pulley?
3. Does anyone have any recent experience with EDIS on an old six? Any ignition maps you'd like to share?
I'm not sold on EDIS, but it sounds like fun to me.
