Another Turbo 200 nears completion....
cudaz101
Post #301 by cudaz101 » Wed Apr 12, 2006 4:39 am
I for one am patiently waiting for Version 2.0...heh
You have my undivided attention, as I would REALLY like to build a Turbo setup for my old Iron 223ci in my 59 f100...
Thanks for your dedication and sharing all your findings. I think I have read and re-read this whole thread 10+ times...heh
Thanks again,
Brad
Linc's 200
Post #302 by Linc's 200 » Wed Apr 12, 2006 12:50 pm
Y'all may have to wait a little longer, I just have been so busy lately, trying to get the real important irons out of the fire, first!
(Or is it keep them in? The toys have to wait for later)
Linc's 200
Post #303 by Linc's 200 » Sat Dec 30, 2006 1:25 am
To the top, just for fun
hasa68mustang
Post #304 by hasa68mustang » Sat Dec 30, 2006 7:21 am
Linc's 200 wrote:To the top, just for fun
so have any plans?
According to Matt our cars will be elevnty billion times faster than all of yours because our carbs flow 500cfm!!!!
addo
Post #305 by addo » Sat Dec 30, 2006 7:23 am
Why does it show seven pages of posts, but when I click on the last page, it says something about not existing?
Is that my proxy?
Linc's 200
Post #306 by Linc's 200 » Sat Dec 30, 2006 8:31 am
addo wrote:Why does it show seven pages of posts, but when I click on the last page, it says something about not existing?
Is that my proxy?
Not familiar with how the software operates
Post #307 by Guest » Sat Dec 30, 2006 10:00 am
Question for Linc or anyone else :)
Can all the tubing be made out of regular exhaust pipe or do you need somthing of a thicker gauge, especially the "J" pipe?
Does it hurt to mig it all together vs tig welding? I have a mig welder and am good at it but dont have access to a tig nor have I ever tig welded somthing before.
Do you have to run a intercooler or can you start out without one.
I know that the optimum compression is around 8.5:1 but what happens if you boost a higher compression engine?
Cut the boost and timing back?
350 cfm carb Holley....right??
To hook up all this to a very expensive dual exhaust system, can you just Y it back together from the down pipe?
And I know....turbocharging by Hugh Macinnes (sp)
Oh...BTW, I made this a sticky
Thanks,
Doug
Linc's 200
Post #308 by Linc's 200 » Sat Dec 30, 2006 1:33 pm
Hi Doug, thanks for making it a sticky .... though the whole thread could be gone through and cleaned up quite a bit and knocked down to about 3 pages!!
Mustang_Geezer wrote:Can all the tubing be made out of regular exhaust pipe or do you need somthing of a thicker gauge, especially the "J" pipe?
AVOID at all costs thin walled pipe. The thicker, the better it can handle the weight, heat and stress. I have seen some pretty nice installations fail after about a year, because thin-walled pipe can't take the abuse. The scraps I welded together are actually from a Ford Explorer....and the wall thickness is abnormally thick, maybe about .080"?? Maybe it's just .065" but it is definitely thicker than plain exhaust pipe. Another nice thing is the scraps I used are all mandrel-bent pieces from the factory. I don't have a "crush" bent piece anywhere. Best thing is, it was all FREE!!
Mustang_Geezer wrote:Does it hurt to mig it all together vs tig welding? I have a mig welder and am good at it but dont have access to a tig nor have I ever tig welded somthing before.
MIG is just fine. I used the TIG on a lot of the intercooler pipe because that was much thinner wall thickness, and it is a lot easier to fill gaps with TIG than MIG if the pipes don't meet up perfectly. All my exhaust pieces were MIG'd, IIRC.
Mustang_Geezer wrote:Do you have to run a intercooler or can you start out without one.
An intercooler will allow you to run more boost, or lower octane fuel...depending. Any time you get the air going into the engine cooled down, you reduce the engine's tendency to detonate. If all you have is 91 octane fuel, an intercooler may help you run a few extra PSI of boost.
It also depends on the efficiency range of the turbo. If you are forcing a "too small" turbo to push more than it should be, then the air temps coming out of it will be VERY hot. An intercooler will help to prevent heat damage from all parts downstream.
Mustang_Geezer wrote:I know that the optimum compression is around 8.5:1 but what happens if you boost a higher compression engine?
Actually, 8.5:1 isn't the best for ALL engines. It really has a lot to do with the shape of the combustion chamber, whether the head is iron or aluminum, altitude, fuel octane used, engine operating temp, etc.
Boosting a higher compression engine will require higher octane fuel, and/or a system that injects alcohol and/or water.
Mustang_Geezer wrote:Cut the boost and timing back?
Reducing timing will reduce detonation but will also kill power if it is the only method used to prevent detonation.
SOME timing reduction is necessary no matter what, since a densely packed fuel air charge in the cylinder will burn faster no matter what (since the molecules are a lot closer together). But too much retard kills power.
Mustang_Geezer wrote:350 cfm carb Holley....right??
Depends on what you are comfortable with. My next carb is going to be a 2100 Motorcraft carb, because:
1) Has annular venturis already
2) has a solid float already
3) you can pull the top off to change jets without dumping fuel everywhere
4) The top is bolted down .... with a 5/16" stud! No bowl gaskets to leak fuel out of the bottom of the bowl
Cons are....single needle inlet looks to be about .080" or so...that could be a problem.
When being blow-through.....smaller carbs are a lot easier to tune than large ones. The better the pressure drop through the carb, the better the signal strength at the venturi. You want good, positive fuel flow through the venturi at all times. I think you can get too small, but even my 1.125" venturi 1-bbl carb would have been good for a high 12-second run with a good launch.
Mustang_Geezer wrote:To hook up all this to a very expensive dual exhaust system, can you just Y it back together from the down pipe?
Sure... many guys split the exhaust right after the turbo into a "Y". The build on my 32 valve 4.6 liter is going to have a "Y" immediately after the turbo outlet.
Mustang_Geezer wrote:And I know....turbocharging by Hugh Macinnes (sp)
A good book for the bare basics ..... it is getting a little dated, though. It could stand to be modernized a bit.
Post #309 by Guest » Sun Dec 31, 2006 8:54 pm
Cool...Thanks! :D
I have access to "used" OEM exhaust systems so I'll be on the lookout for suitable pieces!
Another question,
Is it "better" to run a J pipe like you did or make a manifold like Will did or does it just depend on how much performance you want?
If a manifold is better any ideas on the design of one?
I have 2 flanges I had made several years back and I have mandrel bent U header tubes and I was going to weld a manifold together but lost interest in it...still have the tubes and flanges though.
Not looking for an 11 second ride.....14's or 13's would be fine by me and the simpler the setup the better! :D :D
Thanks,
Doug
Linc's 200
Post #310 by Linc's 200 » Sun Dec 31, 2006 11:03 pm
Mustang_Geezer wrote:Is it "better" to run a J pipe like you did or make a manifold like Will did or does it just depend on how much performance you want?
A "J" is fine for many applications.
The absolute best set-up anywhere is each exhaust port feeding it own tiny turbo. They do make them that small, but that is extremely expensive. The next best thing is a full tubular header with equal length tubes. Also expnsive.
Straight sixes have one thing most engines don't:
A pair .... of three cylinders
HUH? The engine fires one of the front cylinders, then one of the back cylinders, etc. (1-5-3-6-2-4) The perfect place to put the turbo is right between cyls 3 and 4, and then use a divided turbine housing so cyls 1-2-3 feed one side and cyls 4-5-6 feed the other side. This makes a big difference in spool up time. If you look at straight six diesels, they almost always have this set-up.
Will and Kelly's log-type header is a compromise. In that case, it is just most convenient to put the turbo way up front, where there is space. If that pesky shock tower wasn't there, it would be best to put the turbo in the middle and split the flow.
Does10s
FSP Moderator
Post #311 by Does10s » Tue Jan 02, 2007 10:48 am
Linc's is right!
If the shock tower wasn't there, our header would be a 3-into-2 setup like Linc's described.
A log header (like our's) is just an easy way to get the desired results with limited space.
Will
'86 Mustang, Turbocharged, Best ET: 10.70@132.
'69 Mustang Sportsroof, 351w, auto
'63 Falcon, Turbocharged 250, C4, 9", Best ET: 10.64@127mph 11/21/14
Post #312 by Guest » Wed Aug 01, 2007 4:47 pm
hay man i like the car and your power adder.
i would like to when im finshed line up your turboed 200 fox and my soon to be dune twin turboed 300 fox thats would be fun.
its just a six
Post #313 by its just a six » Mon Sep 17, 2007 1:05 am
So, what's the latest on the new engine,1/4 mile runs etc??
Have not heard anything new in a while???
jamyers
Post #314 by jamyers » Wed Oct 31, 2007 1:50 pm
its just a six wrote:So, what's the latest on the new engine,1/4 mile runs etc??
Anything new, Linc?
(and why do I get "no posts exist for this topic" whenever I click on the 7th page?)
James - '62 Ranchero (200cid), '71 LeSabre (464cid)
The ONLY safety device we need is a 6" sharpened steel spike bolted to the center of the steering wheel of EVERY vehicle.
Emergency Rooms and Funeral Homes will be busy for a week or so, then I predict a dramatic drop in vehicle accidents.
Linc's 200
Post #315 by Linc's 200 » Wed Nov 07, 2007 5:00 am
jamyers wrote:Anything new, Linc?
Not sure about the errors on page 7....
Nothing new, and won't be. I have had waaaaaay too many irons in the fire at one time and have been slowly pulling them out, one at a time. One of those irons is anything drag racing related. I am going to be selling everything on ebay that has anything to do with turbos or carburetors or slicks or six bangers.... (blah blah blah) :-(
I have a lot of cool stuff, too.....FSPP cam (brand new), two brand new sets of forged pistons, some race prepped forged rods with ARP bolts, good blocks and heads, etc. etc. etc. It has all gotta go.
pacer
Post #316 by pacer » Fri Jul 11, 2008 5:53 pm
Simply awesome!!!!! I love the buildup!!! MAN O MAN!!!! 13sec on a 1bbl WOW!!! :lol: :shock:
pacer
Post #317 by pacer » Fri Jul 11, 2008 7:22 pm
Have you ever considered running Propane or LPG?? Are'nt the 1bbl propane carbs not affected by pressure?? Plus with the higher octane?? Who knows what the outcome might be?? :D
ManikMaster
Post #318 by ManikMaster » Mon Oct 06, 2008 2:14 pm
I did elect to go with a Front mount intercooler, because just playing with the car running and my hand over the compressor outlet, the air coming out was WAAY hotter than I expected it to be (when air is compressed it heats up) I didn't want to pump all that hot air straight into the carb.
When air is compressed it cools down for example making dry ice is a compression of co2 in gaseous form...not being a know it all...just physics...I really enjoy reading this thread by the way!!!
I66coupe
Post #319 by I66coupe » Mon Oct 06, 2008 11:50 pm
ManikMaster wrote:When air is compressed it cools down for example making dry ice is a compression of co2 in gaseous form...not being a know it all...just physics...I really enjoy reading this thread by the way!!!
You have it backwards, compression heats, expansion cools. Think: diesel.
Rande "The Tachyon"
N4ZYV
1966 I6 Coupe.
1965 Jeep Gladiator
1937 International Pickup
1937 Chevy pickup
"If you find yourself in a fair fight, your tactics suck"
fastfalcon_19
Post #320 by fastfalcon_19 » Tue Mar 10, 2009 9:55 pm
BergerFromage wrote:MAN you guys need to get a step by step on how to do this!!!
i never really was too interested in putting a turbo on the motor i have now i was going to wait till later but now i REALLY want to do it
every one that has done this needs to compile a list of EVERYTHING that is needed and the prices, then do a step by step with pictures so people like me that have NO idea what is involved or how much time and money it takes can do this
im with nathan, a step by step would be killer, or just a whole whack of pics so we can see the whole project!!!
Grandmas6
Post #321 by Grandmas6 » Wed Mar 11, 2009 10:15 am
I'm really new here. I think this is my first post. I wanted to say how awesome this thread is. I never even thought about ever adding a turbo before reading this, but now, when I get around to doing the engine, it's a possibility.
That page where Linc first gets massive boost is a trip to read.
My project:
1966 Mustang. My dad became the mechanic on it when my grandmother became the car's second owner in 1967. Dad had a one-man professional shop from 1972 to 2003 and before that worked at a Ford dealership as a mechanic.
I'm the third owner. 200 block has never been pulled. 100,056 original miles. Bone stock. Good strong, smooth runner. 1967 C4 transmission. Rebuilding front suspension and doing Shelby Drop this winter. Added Monte Carlo bar. Should be back on its tires in four weeks. Did a lot of rust repair and then extensive body repairs after an uninsured driver took me out almost four years ago. Repainted two years ago. Gets about 1,500 to 3,000 miles from April to October.
I was a newbie when it came to the body, so it's a 20 footer.
Anyway, go Linc!!
blue beast
Re: Another Turbo 200 nears completion....
Post #322 by blue beast » Thu May 14, 2009 12:52 pm
I have to admit nice fabrication skills! This is exactly what i want to do on my 1980 Stang, but i figured i'd first deal with the shortcomings of the stock head and intake...i need to look over more of this thread but you're on the same track as i want to go! how much will ya sell the settup for? J/k..
woody88
New Member
Post #323 by woody88 » Wed Jun 10, 2009 3:47 am
I must say I read this whole thread today, not the quickest task, and it brought tears to my eyes and ideas to my brain. I'm getting an 81 Fox with a I6, and t-roofs 8) , and this thread has made me giddy as a school girl. All I have is a turbo from an 89 chrysler lancer and have no clue what it is, but the car is free and runs so my money can be invested in parts. I look forward to reading through this thread many many times... was totally worth reading all 7 pages . Oh and great work.
:wow: :wow: :wow: :nod:
JOSH1966200
Post #324 by JOSH1966200 » Wed Jun 24, 2009 2:21 pm
a 2.3 svo piston swaps out with stock to up compression i have 2 for sale because i needed 2 sets :thumbup:
66 mustang coupe 200 punched 30 over headers autocraft 2100 front disks 4 speed and a 8 inch posi 4:11
80 mustang hatchback 200 t5 5 speed and 2:80 gears 51 mpg highway
82 f100 swb 300 c6 9 inch rear 3:50 gears
62 ranchero 170 2:77 3 speed 6.5 rear 3:90 gears top speed is 1/2 the speed of smell
Anlushac11
RC/TS Moderator
Post #325 by Anlushac11 » Thu Jun 25, 2009 11:29 am
2.3L SVO used a 2.3L Lima OHC motor.
The 2.3L you are referring to is a 2.3L HSC which was based on the tooling of the 200 inline six.
Either way that gives you cast pistons which are not a good choice for a turbo motor. If your going turbo I recommend biting the bullet and buying forged pistons.
I am building a turbo 200 and went forged pistons. Couldnt really afford them but also felt I couldnt afford not to as a rebuild if anything went wrong would be expensive.
As for the Lancer turbo IIRC that is a 2.2L with a Garrett T3 but the T3 on the Chrysler is unique to the Chrysler. Different mounting flange and low A/R to spool up faster.
3.3L n C4 installed, working on wiring for Duraspark II, trans lines, fuel lines, carb linkage.
rocklord
Post #326 by rocklord » Thu Jun 25, 2009 5:03 pm
JOSH1966200 wrote:a 2.3 svo piston swaps out with stock to up compression i have 2 for sale because i needed 2 sets :thumbup:
I checked the specs on a piston for a 2.3L OHC engine used in the SVO. Here they are.
Bore 3.81
pin diameter 0.912
Compression height 1.59
The specs for the 200/250 piston is: Bore 3.68, pin diameter. 0.9122, Compression height 1.500
The piston is 0.13 larger in diameter and would not fit the block.
Dan
Currently Own
1965 Mustang, 200CID, 3Spd
JOSH1966200
Post #327 by JOSH1966200 » Tue Jun 30, 2009 2:15 am
im buildin one of my own did you use type of gasket between the turbo housing and your j pipe adapter :?:
JOSH1966200
Post #328 by JOSH1966200 » Tue Jun 30, 2009 2:17 am
could be that my block was bored but the svo swap worked for me
rocklord
Post #329 by rocklord » Tue Jun 30, 2009 11:18 am
JOSH1966200 wrote:could be that my block was bored but the svo swap worked for me
Measure one of the extra pistons you have and tell us what the diameter is.
The recommended maximum overbore for a 200 block is +0.060".
To use a SVO piston from a 2.3L turbo, you would have to overbore +0.130.
Should not be possible to use a SVO piston.
Dan
Currently Own
JackFish
Post #330 by JackFish » Tue Jun 30, 2009 12:23 pm
http://en.wikipedia.org/wiki/Ford_HSC_engine
The HSC ("High Swirl Combustion") is an automobile engine from Ford Motor Company sold from 1984 until 1994. It was produced in Lima, Ohio, largely using tooling and designs adapted from the predecessor 200 CID straight 6.
The 2.3 L (2301 cc, 140 CID) version was introduced in 1984 for the Ford Tempo/Mercury Topaz. Bore is 3.68 in (93.5 mm) and stroke is 3.3 in (83.8 mm)[1]. This engine produced 90 hp (67 kW) and 125 ft·lbf (169 N·m) of torque[2].
This is the one with the same piston diameter.
Yup, I bought another one.
1996 Chevy Caprice 9C1 (3)
1999 Dodge Ram 2500
JOSH1966200
Post #331 by JOSH1966200 » Thu Jul 02, 2009 2:59 am
my bad they are tempo pistons the dude i bought them from marked them wrong
cyoung67
New Member
Post #332 by cyoung67 » Fri Jul 31, 2009 11:32 pm
I'm crushed............ Read though and was excited about the possibilities of V2.0.
Anyone know how Linc's 200 is doing? I hope all is well.
Rev
64 200 ranchero
Post #333 by 64 200 ranchero » Fri Nov 27, 2009 8:48 pm
how do you regulate the boost 20 psi of boost would require how much psi on the waste gate and bov would it all be at 20 psi or would they be regulated differently
60 ford ranchero daily driver. 200 tri power, modified c4 trans, ds2 distributor, msd programable 6al2, weber ict's, 8" rear end with full spool, 3.80 gears, 245 tires, CI dual out header, Dynomax muffler, 114hp shot wet nitrous kit. JE Forged pistons, 280 110lc cam, around 11-1 compression.
mike1157
Post #334 by mike1157 » Sun Dec 01, 2013 11:09 pm
64 200 ranchero wrote:how do you regulate the boost 20 psi of boost would require how much psi on the waste gate and bov would it all be at 20 psi or would they be regulated differently
Unless the waste gate had a 20 psi spring in it,(unlikely) then boost was controlled via an external boost controller (either manual, or electric) that applied pressure from the turbo to the top of the waste gate diaphragm, effectively increasing the force of the waste gate spring. How much additional pressure to achieve 20 P.S.I. is directly related to what spring was in the waste gate in the first place. The BOV has nothing to do w/ regulating boost, it's purpose is to vent boost to atmosphere when the throttle is closed.
1978 Ford Fairmont Futura project: "The Gila Monster" Xflow'd Megasquirted, MPFI'd, DIS, T/C'd, A2WI/C'd 250, 4R70W shifted, and 8.8, 3.55 gear rearended.
Travis JR
Post #335 by Travis JR » Wed Jun 28, 2017 4:47 am
Hey I know this is a really old post but do you mind giving me some updated information on how you turbocharged your inline 6. I'm trying to turbocharge my 66 mustang inline 6 and was just wondering if you could give me some tips and pictures if you still have the car on how you did it. How much did it cost, was it simple to do? Thanks
Return to “performance tech”
