A common question is, “What is porting?†So I have drawn up some pictures to show a stock intake port, its problem areas, and a possible approach to a modified head.
The first drawing is just the stock head.
Some of the areas to take special note of are 1. the sharp edge where the combustion chamber meets the block surface. 2. the boss of the valve guide protruding into the port. 3. the lip created by the valve seat insert. and 4. the shrouding of the intake valve by the combustion chamber. The areas are highlighted.
Now - don't laugh at my weak PhotoShop skills - a modified port. I worked on the four areas mentioned above. They are highlighted. You'll notice that there is no attempt to enlarge the port itself. The combustion chamber has been enlarged slightly to unshroud the valve and to grind the sharp lip left after milling - getting rid of the sharp lip is ESSENTIAL or it will create a hot spot.
The bowl work on the seat lip can easily be done by the machinist when doing a three-angle valve job. The valve guide work is easily done with a Dremel and some patience.
Once again, I hope this clears up some of the confusion. There's NOT much that can be done past the bowl area because of the cast-on log manifold.
