In Rough Form
This is not a guide for complete novices. It assumes
1. Commonsense
2. A fair smattering of tools available
3. Proficiency with those tools
4. Patience and observational skills
Start with the complete unit – either from a wrecker, or off the car. Remove the cap, rotor and cap spacer where fitted.
Unclip the coil from the wiring if not done already. Undo the coil bracket, and unclip the suppressor. Clean the coil, bracket and suppressor with Prepsol and paper towel.
STORE THE COIL UPRIGHT OR IT WILL LEAK
Then it may not have enough cooling oil, and burn out fast.
Now for the distributor.
Clean the exterior amply with Prepsol and paper towel. Avoid any cleaning or solvent sprays at this point. Scrape heavy grunge away with a flat bladed screwdriver. Your unit should be now 90% clean on the outside; maybe some brownish tarry stains from oil, maybe some oxidisation of the alloy.
Unscrew the cover of the module. The screws have no washers. Unplug the module. You may need to hook a small flat bladed driver or bradawl into the Utilux clips to slide them off. The module can be removed by hand now – just lift the locating pins clear of the metal it sits on. The output wire grommet (black, rectangular) can be prised or pulled up and out of its slot in the side of the distributor body; now the red and green wires are free.
Clean the module cover, mounting screws, output lead and module with the Prepsol and paper towel.
• Note that the module has silicone grease on the base for heat transfer assistance. You may wish to be careful not to contaminate other things to be painted, by scrubbing up thoroughly at the completion of cleaning the parts.
Next to go is the vacuum modulator. Remove the two screws with attached washers, and the modulator will flop around on the side of the distributor.
TAKE CARE NOT TO TWIST THE UNIT
Now, look in the side of the distributor where the output wires' grommet was removed, and you will see the end of the vacuum module control arm. A thin, small flat blade screwdriver is handy here. You need to prise the arm downwards from its inverted pin on the (breakerless) "breaker" plate. There is no circlip or split pin, it just gently is worked down and free. The vacuum modulator can then be removed and cleaned.
It's getting more fun by the minute. Now clamp the distributor shaft end in a soft-jawed vice (wood, nylon or aluminium jaws are fine), standing it upright.
There is a circlip type clip at the centre top which has to be prised off. It will want to spin around; stop one end with a flat bladed screwdriver while you prise the other out of its groove, little by little. A smear of oil on the shaft (usually rusty) will help you slide it up and off. Remove the spring "finger" washer underneath.
Remove the distributor from the vice. Using a smaller hammer (Warrington or cross-pein is ideal) with about a 1" face, tap the upper shaft end firmly while holding the unit in your hand, at the gear end. With repeated tapping, you will see the star-shaped inductor slide up the shaft, and eventually be removable.
Below it is another circlip, same as the first. Remove in a similar manner, noting that it has to pass over the first clip's groove, so twice the fun.
AT ALL TIMES TAKE CARE NOT TO FORCE OR PRY AGAINST THE PICKUP COIL. IT IS FRAIL AND EXPENSIVE.
Place the distributor sunny side up in the vice again. By rotating the breaker plate, you will see two Allen head bolts through slots in the plate edges. Loosen and remove these with a 3mm key. The plate with attached coil can now be lifted out.
Turn this assembly over on the bench, and using a well-fitted screwdriver, remove the three brass crews securing the coil. Place the coil to one side for safekeeping. Prise the c-clip from the top centre of the breaker assembly, remove the two flat washers below it, separate the upper and lower breaker parts and remove the thin flat washer from the underside of the mutual friction surface.
Clean the washers, and both parts of the plate assembly.
Remove the distributor from the vice again, and support the drive gear plain section on block of hardwood, while driving out the rollpin. The gear can be gently tapped off the shaft, and there may be a flat washer at the upper end, against the alloy casting. Clean the gear, shaft end and rollpin. Lift the shaft assembly free of the housing. Note there is a thin thrust washer in the upper housing, that may be either stuck to the steel bush in the casting, or clinging to the underside of the advance system.
Remove the tiny oblong cover from the side of the distributor body by prying free; it and the housing can now be fully cleaned.
You are now left with the central shaft assembly, from which the counterweight springs can be carefully prised. Next to remove are the E-clips holding the counterweights on, the counterweights themselves and nylon washers below. Clean all and set aside.
At the top of the shaft, pick out the felt disc with a sharp tool. Keep it as intact as possible. The next step is one of the hardest. Clamp the upper part (above the weights) of the shaft in the vice, so that you can aim a flooring punch down the shaft hole at the top. Centre your punch, and with several firm blows, drive the lower section of the shaft free.
Be careful to not lose the c-clip or flat washer from inside this upper shaft hole. Twist off the plastic advance limiter sleeves from the upper shaft. Clean the parts, and you are done with the dismantling.
