OK here is a stirrer for you. 1977 Aussie F350 Chassis. 1948 F4 truck cab with modified Peter Built Sleeper cabin.
Motor is a 1991 Cummins Inline Turbo ( 6BT 5.9 Litre 360 Ci ) with Cummins factory adaption to a Ford C6 Auto and a US Gear Over drive coupled to that. Dana rear end has had the ratio changed. Plans are to run it on Bio Diesel with LPG ( Propane ) Injection.
	Chassis and brakes etc. are all stock F-350 as is the steering column.
