THE FRENCHTOWN FLYER
5K+
Subscriber
Supporter 2023
Supporter 2022
Supporter 2021
Supporter 2020
Supporter 2018
I used to run a Ford toploader wide-ratio trans in my altered, using a Mr. Gasket vertical gate shifter and a super-low Liberty 2.87 first gear. The shifter came up between my legs. That will be nearly unbreakable in your ride. It will set you back about two grand, but you won't have to worry about breaking it.
