Hi, X2. The early Ford six could have a large or small bellhousing, with a high mount starter. The V 8 could have a 5 or 6 bolt bellhousing with a low mount starter, which won't fit the 6 cylinder. The C 4 could be case fill or pan fill. The bellhousing comes off of C 4 trannies, so if you have the wrong bellhousing you can switch it. Get the Ford Falcon Performance Handbook to learn about bellhousing choices and get the most out of your Ford 6. Good luck
