Diesel Inliner.
Cool23
Diesel Inliner.
Post #1 by Cool23 » Sat Mar 10, 2007 12:48 am
OK here is a stirrer for you. 1977 Aussie F350 Chassis. 1948 F4 truck cab with modified Peter Built Sleeper cabin.
Motor is a 1991 Cummins Inline Turbo ( 6BT 5.9 Litre 360 Ci ) with Cummins factory adaption to a Ford C6 Auto and a US Gear Over drive coupled to that. Dana rear end has had the ratio changed. Plans are to run it on Bio Diesel with LPG ( Propane ) Injection.
Chassis and brakes etc. are all stock F-350 as is the steering column.
V8's are great but Six Inlines Just Fine. Cummins Advert.
The link to my project on this forum http://fordsix.com/forum/viewtopic.php?t=41598
addo
Post #2 by addo » Sat Mar 10, 2007 1:26 am
Nice one. I think the door into your sleeper could be taller though.
You wouldn't know what integral intake/exhaust (turbo) manifold set has "OMC" cast on the outside, would you? Tripped over one at work the other day (a backyard full of junk where the shed was demolished).
Cool23
Post #3 by Cool23 » Sat Mar 10, 2007 4:25 am
addo wrote:Nice one. I think the door into your sleeper could be taller though.
Thats the toolbox :lol: Do not forget we are Right Hand Drive so the sleeper door is on the other side. Sleeper Cabin has been Chopped Channeled and section to fit and to show you here ( bottom of post ) is a photo prior to it being fitted.
addo wrote:You wouldn't know what integral intake/exhaust (turbo) manifold set has "OMC" cast on the outside, would you? Tripped over one at work the other day (a backyard full of junk where the shed was demolished).
On the Cummins ? It is Factory Holset. Sorry "OMC" has got me :?
Sounds like a Marine Turbo but then I have to admit my Turbo knowledge is not very good. Try a GOOGLE search :)
Cool23
Post #4 by Cool23 » Tue May 01, 2007 6:42 pm
Update for you.
Cool23
Post #5 by Cool23 » Wed Jul 04, 2007 5:40 am
Making the wiring loom this week so will be ready for panel and paint soon. :D
woodbutcher
Post #6 by woodbutcher » Thu Jul 05, 2007 3:50 pm
:D I think that OMC means Outboard Marine Corporation.In other words,
Mercury.
Leo
Otto von Bismarck
Cool23
Post #7 by Cool23 » Thu Jul 05, 2007 6:49 pm
:D :shock: yes OMC - Yes there is a marine version of this same motor.
The 6BT has been used in many applications such as Pumps, Industrial applications as well as the Dodge Ram etc.
Cool23
Post #8 by Cool23 » Fri Aug 17, 2007 5:47 am
Finished the wiring loom this week and today fired the Cummins up. Started first turn of the key. :D :D :D :D :D :D :D
woodbutcher
Post #9 by woodbutcher » Fri Aug 31, 2007 1:38 pm
:D Duhhhhhhhhhhhhhhh!Made a booboo on earlier post.OMC=Johnson. :oops: :oops: :oops:
Leo
Otto von Bismarck
Platinum_Racing
Post #10 by Platinum_Racing » Mon Dec 03, 2007 12:29 am
*Sigh*
I miss my Cummins. :(
1986 Ford F-150 Stepside
-300 I6/4 Speed Standard/3.55 Gearing
MSD - Edelbrock - Spectre - Carter - APC - Lund - Pioneer - Visonik - SunPro - Grant - Autolite - JVC
Cool23
Post #11 by Cool23 » Mon Jan 21, 2008 6:44 pm
December 2007 Ready for the tear down for Panel and Paint.
Sleeper Cab at the paint shop. 25th January 2008.
21st January 2008 - Here is the chassis ( 1977 F-350 ) with motor and gearbox etc minus the Cab and sleeper cabin. Still some minor work to be done on the chassis.
Cool23
Post #12 by Cool23 » Mon Jan 21, 2008 6:52 pm
Here is the cab. A lot of work to be done here.
Doors have been fixed and we have added Bear Claw latches using the existing door mechanism we have internal lock as per original Door handles, on the outside the handles have been replaced with an aftermarket handle that has the key locks built in. All very trick. Hole in the firewall is for the F-350 brake booster / mastercylinder.
Cab has very little rust so will be easily fixed. All the white marks are holes we have to weld up. New floor is Chequer plate steel.
addo
Post #13 by addo » Mon Jan 21, 2008 7:44 pm
Are you using a Falcon or similar column?
Through the cab screen photo, is that "Gold Teak" coloured Proof-Tint woodstain on the shelf? Fourth shelf down from the top, about 16 inches to the left of the grey-blue plastic container...
Cool23
Post #14 by Cool23 » Tue Jan 22, 2008 1:00 am
addo wrote:Are you using a Falcon or similar column?
77 Aussie F-350 Column is the same as the Aussie Falcon, even the same wiring connections etc.
addo wrote:Through the cab screen photo, is that "Gold Teak" coloured Proof-Tint woodstain on the shelf? Fourth shelf down from the top, about 16 inches to the left of the grey-blue plastic container...
I have no idea as it is not my workshop. :? :shock:
Just try some paint thinners ADDO and see if that works for you :lol:
Cool23
Post #15 by Cool23 » Fri Feb 22, 2008 9:13 pm
23rd Feb and update time.
4th Feb In primer.
21st Feb painted.
Cool23
Post #16 by Cool23 » Thu Apr 24, 2008 5:40 am
24th April and time to update you again.
Truck Cab is ready for paint. Well still some minor rust to repair. Cab has been strengthened in many places such as in the floor area and round the door hood / bonnet hinges etc. Hood /bonnet ( you do not call it a Bonnet in the USA or Canada do you ? ) has been heavily braced underneath as well. I have found new handles to use and these have the Key in the handle. beer Claw latches have been added using the old F4 mechanisms so the door has dual locks with the handle locking set up.
Sleeper Cab is now back in place on the chassis. All the front sheetmetal ( Guards, Bonnet, Running boards ) has yet to be delivered to the painter. All the rust in those has been fixed.
Lazy JW
FSP Moderator
Post #17 by Lazy JW » Thu Apr 24, 2008 8:43 am
Nice 8) 8) 8) 8)
"The White OX" 1974 F-350 300-6, Stock single exhaust, Carter YF, T-18A, Dana70 w/4.11, Flatbed dually w/dump bed. "Where no oxen are, the crib is clean, but much increase is by the strength of the ox" (Proverbs 14:4)
Cool23
Post #18 by Cool23 » Mon May 19, 2008 8:57 pm
19th May. Cab has been partly sand blasted so final rust repairs can be done.
A last look at the drivers door with the old sign writing. I will reproduce the signwriting with a new theme. Also note the new door handle with the key lock built in.
Cool23
Post #19 by Cool23 » Thu Jul 31, 2008 11:13 pm
1st August cab is now in primer and rust free.
Floor and roof have body deadner panels. Should be in primer soon and before then of the month will be in color.
Cool23
Post #20 by Cool23 » Mon Aug 04, 2008 12:41 am
4th August and now in Grey Etch primer.
Also had to fix up the door hinges an at the same time MAKE as I could not find a place that sells new door hinge pins.
TCIC 300ci superbeast
Location: yellow springs ohio just south of springfield and just east of fairborn
Post #21 by TCIC 300ci superbeast » Mon Aug 04, 2008 11:08 pm
thats really sweet. but whats up with the wing?
1978.5 f250xlt ranger custom super-cab 4x4 "superbeast" turbo300/ZF S542/BW1350/np205d dana 44HD/dana60
dec.1978 f150xlt custom 4x4 "six shooter" parts truck for super beast
2004 2.0 dohc 5speed focus DD "toycar"
truck club OHIO MUD SLINGERS
walk softly and carry a big six
Cool23
Post #22 by Cool23 » Tue Aug 05, 2008 10:52 pm
TCIC 300ci wrote:thats really sweet. but whats up with the wing?
The wing has a few tricks :wink: and hides a mass of LED's in both indicators and stop tail lights.
Post #23 by TCIC 300ci superbeast » Tue Aug 05, 2008 11:23 pm
O :o
Patrick66
Post #24 by Patrick66 » Thu Aug 07, 2008 9:05 pm
i like it. cant wait to see it finished.
Cool23
Post #25 by Cool23 » Fri Aug 08, 2008 9:31 pm
Me to :D
Cool23
Post #26 by Cool23 » Mon Aug 11, 2008 5:48 am
At last. Will be in Top coat / color next week.
Post #27 by TCIC 300ci superbeast » Mon Aug 11, 2008 10:38 pm
so from lookin at the sleeper ur going with a green like calypso green?
Cool23
Post #28 by Cool23 » Tue Aug 12, 2008 9:31 pm
TCIC 300ci wrote:so from lookin at the sleeper ur going with a green like calypso green?
1966 Aussie Falcon colors - green velvet metalic ( original color but with more metalic ) Sleeper, cabin, bonnet and Merino White for the guards.
shmoozo
Post #29 by shmoozo » Tue Aug 12, 2008 9:37 pm
Nice color choices. Tasteful. That's going to be very easy on the eyes.
Out of curiosity, what are your plans for the wheels? Alloy? Chrome? Painted steel?
"Every normal man must be tempted at times to spit upon his hands, hoist the black flag, and begin slitting throats."
-Henry Louis Mencken
Cool23
Post #30 by Cool23 » Wed Aug 13, 2008 9:43 pm
Wheels are Alcoa Hots Shots. Chosen because they have a similar look to the Halibrands and they look good as duals. If you go back you will see the rear wheels are on. I had to import three steel wheels from Canada for the spare and the inner duals.
Post #31 by TCIC 300ci superbeast » Wed Aug 13, 2008 10:24 pm
srry if you had already said this but what are you going to do with this truck?
shmoozo
Post #32 by shmoozo » Thu Aug 14, 2008 3:50 pm
Nice wheels. That is going to be a mighty fine looking truck.
Cool23
Post #33 by Cool23 » Thu Aug 14, 2008 6:03 pm
TCIC 300ci wrote:srry if you had already said this but what are you going to do with this truck?
You build it because you can then you - Drive it, show it and just enjoy it :D
Post #34 by TCIC 300ci superbeast » Thu Aug 14, 2008 7:06 pm
all right. u taking it 2 car shows?
looks like it would be good for a camping trip.
02Puffer
Post #35 by 02Puffer » Thu Aug 14, 2008 10:34 pm
This will surely be a beauty when rolling.
If i may ask, are you still planning on lpg injection? It works well in very small amounts for economy, but the cylinder pressure spike during combustion wreaks havoc on the small ends of the rods in bigger volumes.
A decent set of injectors will run about the same for a big lpg kit, and the reliability is awsome. What other diesel work have you done? gassers are great but i love how tweaking an injector pump can net 50+ horsepower. Best of luck withe the build.
~Craig
Daily Driver: 2002 Ford F-250 Super Cab Long Bed 7.3l Powerstroke
Projects: 300 ci Big-Six, C-6
Cool23
Post #36 by Cool23 » Sat Aug 16, 2008 12:31 am
TCIC 300ci wrote:all right. u taking it 2 car shows?
Yes I fully intend to and .....we will run the street hack out of the enclosed car trailer to use whilst the show is on :wink: :lol: :lol: :lol: :lol:
02Puffer wrote:This will surely be a beauty when rolling.
A decent set of injectors will run about the same for a big lpg kit, and the reliability is awsome. What other diesel work have you done? gassers are great but i love how tweaking an injector pump can net 50+ horsepower. Best of luck with the build.
Yes I am running the LPG injection and as yet have to finish it when we reassemble the truck after paint. Only needs one LPG injector before the turbo. I have some good connections with Cummins and cummingracing.com so all will be ok :wink:. LPG will be set only for economy at the early stage so as we burn the Diesel cleaner but that does give us some power advantages. By doing that the motor will run better on the long haul going to shows and events.
Cool23
Post #37 by Cool23 » Sat Aug 23, 2008 12:56 am
23rd August 2008. Cab is in Color and was all painted in less than a day. Doors will be next along with the bonnet and guards.
STEVEN.
Post #38 by STEVEN. » Sat Aug 23, 2008 10:05 am
VERY NICE work going on there,'C-23' :wrench: :smash: :cool: 8) . ~OO6.
Cool23
Post #39 by Cool23 » Mon Aug 25, 2008 3:29 am
All happening here I can tell you.
Out of the paint shop on the 25th August and back on the chassis.
All done.
Next to deal with the Doors, Bonnet, Running boards, Front guards ( Rust remove and paint ) and reassemble the interior of the cab.
Cool23
Post #40 by Cool23 » Wed Dec 31, 2008 5:15 pm
Sadly the web site hosting the later photos gives me this message -
http://mercury.select-servers.com/suspended.page/
so they will no longer appear. Nearly together so will update again soon.
Cool23
Post #41 by Cool23 » Sun Jan 04, 2009 7:09 pm
January 5th 2009.
Here is the Dash. Smiths Guages. LED Lights for indicators and Auto. US gear Overdrive switch to the right and above the dash the Turbo timer.
Steering Column is Ford F-350 or the same as the Falcon here of the same era.
This is the underdash area. LPG ( Propane ) Computer as well as Cruise control, Auto shift controls, Heater Air Con etc.
jdv
Post #42 by jdv » Tue Jan 06, 2009 8:00 pm
Yeah!!! A beautifull truck with a great job in the wirings! I wanna see it finished. It's the right truck to ship a hotrod to car shows haha.
Cool23
Post #43 by Cool23 » Wed Jan 07, 2009 5:27 pm
josedelvecchio wrote:Yeah!!! A beautifull truck with a great job in the wirings! I wanna see it finished. It's the right truck to ship a hotrod to car shows haha.
The best fun will be going to a show with enclosed car trailer behind. Off loading the street hack ( so I can get about during the show ) and then unhooking the trailer so I can drive the truck into the show.
Cool23
Post #44 by Cool23 » Sun Mar 15, 2009 8:51 pm
March 16th and time again to update.
Running boards painted with a body deadener ( gives ripple finish effect ) and color. The black strips are body moulding so you do not step on a painted surface.
Front Guards. Still have to put the grille, headlights back.
What the front looks like at present.
Still a lot to do yet. :wink:
Cool23
Post #45 by Cool23 » Mon Mar 16, 2009 6:07 am
Two of my mates helping me with the project have just surprised me by emailing me these photos. Taken on the 16th whilst I was not about.
shmoozo
Post #46 by shmoozo » Mon Mar 16, 2009 1:30 pm
WAHOO! That thing is looking good there, Cool23. You'll be turning plenty of heads with that thing when it's finished.
:D
Cool23
Post #47 by Cool23 » Wed Mar 18, 2009 8:30 pm
Now have most of the lights refitted.
Cool23
Post #48 by Cool23 » Thu Mar 19, 2009 8:01 pm
20-3-2009.
If you turn this photo side on you can see the SOCK -sleeper cab rubber is now in place.
shmoozo
Post #49 by shmoozo » Thu Mar 19, 2009 10:26 pm
It seems to be coming along nicely now. You appear to be in the assembly stages. Are you finished with the fabrication work?
Also, what plans do you have for the interior of the cab and the sleeper cab?
Cool23
Post #50 by Cool23 » Fri Mar 20, 2009 12:48 am
Only small items to fabricate such as new mounts for the grille stainless steel etc.
I have two seats ready to fit back into the cab. Upholstery is about 90% done. Carpet etc to be fitted. Sleeper cab needs the Flat screen TV fitted along with speakers and AMP etc.
Still a lot to do but it is all happening.
Users browsing this forum: No registered users and 6 guests
