Tri-power tuning
woodbutcher
Re: Tri-power tuning
Post #51 by woodbutcher » Fri Mar 25, 2011 3:11 pm
:beer: Your build and research is looking VERY good.Keep up the good work.On the jet size that you mentioned,unless I read wrong,200mm would be almost an 8" jet.
Good luck and have fun.
Leo
Otto von Bismarck
kevinl1058
Post #52 by kevinl1058 » Fri Mar 25, 2011 5:22 pm
Reduced my jetting back to my Dyno Jet sizes 190/175/190 was getting a weird bog / hesitation when I bumped up to the 200/190/200 jetting. PLus I started getting a lean reading in my 5/6 cylinders. SO I just went back to where things looked the best and to where I had good dyno numbers.
Post #53 by xctasy » Fri Mar 25, 2011 10:11 pm
Sensational Kevin. Either way that's a five second 1/4 mile improvement on a stock 200. Magic! :beer:
kevinl1058
Post #54 by kevinl1058 » Fri Jul 29, 2011 3:58 pm
OK after jetting experimenting and reading my FAST A/F monitor, and a huge thanks to Extacy I did as suggested and went to 185 mains for all three. Cruise readings 13.5/ WOT reading 12.5. Car pulls so much nicer. I was just over jetting with the 190/175/190 WOT A/F was dropping to 10.7..
Gene 64 2dr
Post #55 by Gene 64 2dr » Sun Jul 31, 2011 11:45 pm
Kevin, 16’s won’t be any problem. I’ve run a 16.8 with the stock jet settings. It’s amazing I didn’t smoke it. It wasn’t bad until after the 1/8 then it would just lay down. I hate to guess what the readings were then.
Our setups do not seem that different. I have installed an AF meter and my best numbers to date are a solid 12 WOT and at cruise it varies some between 13.5 and 14.
Jet sizes are 185 on the secondary’s and a 170 on the primary. I have pulled all the plugs and they look great, not a bit lean.
The initial timing is set at 14 with no sign of detonation. My compression ratio is a little lower than yours at just under 9 to 1
Just for reference engine specs are: 200 40over, 78 head ported and polished, stock valves three angle vale job, roller tipped 6:1 rockers, 3 single barrel Webbers, dual roller timing chain, 268/274 cam, CI dual out headers into dual exhaust out back,
I use a T5 to a 3.58 limited slip diff.
I have had too much work to do on the house but should be able to get to the track in a couple of weeks for a new set of numbers. Getting on a dyno is another goal I have for the near future.
Gene
65 Falcon Futura hardtop, FSD’s 250, T5, 4:11’s
kevinl1058
Post #56 by kevinl1058 » Mon Aug 01, 2011 2:55 am
your right on track.. Based on my cruise #'s I could drop down to a 175 primary jet. I like my transitional #'s though running the 185 jet un the primary. I am 3/4 turn out on the idle mixture with an A/F of 13.8 at Idle. WOT is 12.3-12.5.. Much better top end.
WerbyFord
Post #57 by WerbyFord » Wed Jan 01, 2014 12:23 pm
kevinl1058 wrote:your right on track.. Based on my cruise #'s I could drop down to a 175 primary jet. I like my transitional #'s though running the 185 jet un the primary. I am 3/4 turn out on the idle mixture with an A/F of 13.8 at Idle. WOT is 12.3-12.5.. Much better top end.
Kevin,
Hi there, just found this thread and your car thanks to xctasy and the other thread:
viewtopic.php?f=1&t=71224
So, I try to keep a database for the Gonkulator (computer program I wrote), keyed in your combo as best I could, guessed at the Oregon cam at 224-230-110 with a 106 ICL, hyd with .509 .512 lift by blending two Oregon lobes off their sheet. Close?
So the Gonkulator pretty well lined up with your open hood chassis dyno, and said:
GROSS tq/hp (SAE gross, 60F 29.92 dry air, open exhaust, no belts etc)
Torq 214 at 4100
Powr 200 at 5500
Down the track assuming 2800lb w/driver as xctasy assumed (have you weighed it?)
2.30
10.17 at 70.3
15.88 at 85.4
Might go a little faster due to that slick smooth black paint job!!
I noticed you had been to All Ford Day (Woodburn?) the track prep is usually pretty good there at least when we went, its kinda fun to show and run your car at the same show if you want some times or have you had it to the strip since this kinda old thread?
kevinl1058
Post #58 by kevinl1058 » Tue Jan 14, 2014 9:54 am
I have not yet run the car down the track. I was still running airover leafs last time I was at the all ford show. Have since 4 linked so I know the car would hook up much better through the 60'. Will plan on running some 1/8th mile at PIR this spring though. Just eager to see what the car will do.
theman1990
Post #59 by theman1990 » Mon Mar 09, 2015 3:45 pm
Mine's getting closer to being ready to be put on... What did you use to move the center carb fuel intake line to driver's side? Can you possibly e-mail me some good high res pics of your setup on both sides?
