Dying Under Load
65_Stang_170
Dying Under Load
Post #1 by 65_Stang_170 » Sat May 12, 2018 5:34 pm
Howdy!
Just got everything hooked up after swapping to an 1101 and distributor from a '69 250. I think I have the timing and A/F ratio in a pretty good spot. It idles really well, but when I rev up beyond 1500 rpm it stumbles quite a bit. When I tried to drive it out of the garage, I couldn't fully release the clutch without it dying. So, now it's in the driveway while I troubleshoot... Thoughts? Maybe a vacuum leak or something?
1965 Mustang Coupe - 170 I6, T5 Manual Transmission, Weber 32/36 Carb, Amazon Headers w/single exhaust to thrush turbo muffler, Arning Drop
falcon_master
Re: Dying Under Load
Post #2 by falcon_master » Sat May 12, 2018 7:08 pm
I am in no way even close to an expert but I would think that it's a carburetor problem if it stumbles after a certain rpm it could be on of the fuel circuits not working right or the timing not advancing properly. Someone correct me if I'm wrong please
Junior year high school AFJROTC cadet and car enthusiast. Likes all things ford and engines of any company. 64 falcon 2dr sedan,144CI and 3spd column shift. estimated 124,000 miles. Resurrected after sitting outside for 18 years, In process fixing for use as daily driver YouTube channel for repairs coming soon. “Old cars may break but are never broken”-RCR
chad
Post #3 by chad » Sat May 12, 2018 8:27 pm
falcon_master wrote:...could be on of the fuel circuits not working right or the timing not advancing properly. Someone correct me if I'm wrong please
no, I think ur right but w/o bein there I'd say double ck timing 1st, then onto carb if needed (also very far frm ex - spirt)...
wsa111
FSP Moderator
Post #4 by wsa111 » Sat May 12, 2018 8:41 pm
At idle in neutral can you bring the rpms up to 4500 with no load?? if not hook a timing light up & see if you have a steady spark or it jumps around?? If so you may have reverse polarity.
What is your ignition system?? What is your fuel pressure??
Need more info to really pin point your problem. Bill
67 mustang,C-4, with mod. 80 hd, custom 500 cfm carb with annular boosters, hooker headers, dual exh.-X pipe, flowmaster mufflers, DSII dist. MSD-6425CL & MSD-Blaster 8252 Coil. Engine 205" .030" over with offset ground crank & 1.65 roller rockers. 9.5 comp., Isky 262 cam.
65_Stang_170
Post #5 by 65_Stang_170 » Sat May 12, 2018 9:08 pm
Ignition system is a stock distributor and coil from a '69 250. Mechanical fuel pump, so whatever psi that make. I don't have a gauge to test, but its pumping well/normal. I have a manual transmission, and in neutral when I press on the accelerator to bring up the RPMs it goes smooth until about 1500. I continued to press through up to 3500 RPMs and it continued to shake/stumble pretty good. When I put it in first and tried to go it cut out pretty quickly even if I really babied it.
Thanks for the help!
wsa111
FSP Moderator
Post #6 by wsa111 » Sat May 12, 2018 10:02 pm
You have an ignition problem from what you describe.
However just try this, when you bring up the rpms, slightly close the choke blade to richen the mixture.
Disconnect the vacuum advance & see if that makes a difference??
Econoline
Post #7 by Econoline » Sat May 12, 2018 11:59 pm
I'd pull the top and see if all the check balls and the weight are there and in the right place. And check the float while in there.
It ain't gonna fix itself
65_Stang_170
Post #8 by 65_Stang_170 » Sun May 13, 2018 2:33 pm
wsa111 wrote:You have an ignition problem from what you describe.
Thanks Bill. I'll give it a shot and see what happens.
Econoline wrote:I'd pull the top and see if all the check balls and the weight are there and in the right place. And check the float while in there.
I just rebuilt it and the check ball and weight are in the designated spot. Based on the diagram at least.
65_Stang_170
Post #9 by 65_Stang_170 » Mon May 14, 2018 7:48 pm
Just got a chance to try what you suggested: disconnecting the vacuum advance did not seem to change anything. However, closing the choke a bit seemingly cured the issue, and it was smooth and not stumbling up to 3500 rpm. What does this mean?
Thanks!
wsa111
FSP Moderator
Post #10 by wsa111 » Mon May 14, 2018 9:14 pm
You either have a jet clogged or too lean a jet. Need to remove the top of carb & make sure each & every passage is clean. Make sure float level is correct & make sure the float drops when float bowl is empty.
Hope you don't have a major vacuum leak.
Do you have the correct pcv for your engine size? Or do you have a draft tube??
What is the # on the main jet??
65_Stang_170
Post #11 by 65_Stang_170 » Mon May 14, 2018 9:57 pm
wsa111 wrote:You either have a jet clogged or too lean a jet. Need to remove the top of carb & make sure each & every passage is clean. Make sure float level is correct & make sure the float drops when float bowl is empty.
I just pulled the carb apart to make sure everything was adjusted correctly. Float was adjusted when I rebuilt it, and drops as it should with fuel decrease. Current jet is a 61F. I believe I have the correct pcv size for my engine, as it was working just fine before I switched out carbs/distributor. I think I did fix a slight vacuum leak by tightening down the new adapter plate, so we're getting somewhere. I think I need to get a new hose for the PCV as it isn't sealing completely at the vacuum port. Tomorrow's project...
wsa111
FSP Moderator
Post #12 by wsa111 » Mon May 14, 2018 10:07 pm
Per your carb. what is the original main jet size for your carb. ???
Put in a 68 jet & see what happens.
JackFish
Post #13 by JackFish » Mon May 14, 2018 10:11 pm
Sounds like you've gone over the carb pretty well.
Put a timing light on it and see if you're getting proper advance.
If not check the distributor springs.
Yup, I bought another one.
1996 Chevy Caprice 9C1 (3)
1999 Dodge Ram 2500
65_Stang_170
Post #14 by 65_Stang_170 » Tue May 15, 2018 8:17 am
wsa111 wrote:Per your carb. what is the original main jet size for your carb. ???
A 68 Jet was in it originally, but I figured smaller engine = smaller jet? I'll get it switched out tonight and see how that affects everything. Ok, two projects for tonight. New PCV hose and switch the jet.
JackFish wrote:Sounds like you've gone over the carb pretty well.
How do you check how far it has advanced if the timing tab only goes to 14? I've always wondered this...
drag-200stang
Post #15 by drag-200stang » Tue May 15, 2018 8:53 am
Other than the accelerator pump shot, a carburetor is not a fuel injector...It gets sucked in, a smaller engine means less suck and less fuel, to a point it is self adjusting...There is a lot more to it , best to use your air fuel meter.
66 Mustang Coupe
200 turbo w/lenco 4-spd
Went 9's when 10's was fast.
65_Stang_170
Post #16 by 65_Stang_170 » Tue May 15, 2018 8:32 pm
Put in the 68 jet and it seems to be running much better. Got a new hose for the PCV, but I don't know if that affected anything. I was able to drive it around the block, and it felt ok. Need to make a few more adjustments, but moving in the right direction. I give a go again tomorrow, but the battery died (separate charging issue).
On a separate note (charging issue): what are the ramifications for running the car without a voltage regulator? I can't get my charging system to work: new battery, alternator tested several times, tried a few new voltage regulators. It's not giving the battery enough juice to stay charged, so it slowly drains... I accidentally left the VR unplugged, and the alt dummy light didn't light up anymore, and the battery was getting enough juice. Thoughts?
chad
Voltage regulator
Post #17 by chad » Tue May 15, 2018 10:19 pm
"...Thoughts?"
only 1 as I'm no help on electrics (or much else but...)
I've heard the VR are NOT made as well as they once were (is much?) & that many have gone thru enuff w/o gettin a good 1 so as to rebuild an old 1...
C if U can get a Motorcraft? NAPA - Elchign (spelling)?
JackFish
Post #18 by JackFish » Wed May 16, 2018 2:26 am
You need a timing light with an advance dial to check anything over idle.
And if all you're doing is driving around the block it won't charge the battery.
1999 Dodge Ram 2500
65_Stang_170
Re: Voltage regulator
Post #19 by 65_Stang_170 » Wed May 16, 2018 7:39 am
chad wrote:"...Thoughts?"
I've tried a motorcraft/autolite mechanical VR and a few solid state VRs, and neither allow enough voltage to the battery while the car is running.
JackFish wrote:You need a timing light with an advance dial to check anything over idle.
Copy, need a fancy timing light. I know driving around the block won't charge the battery. I've taken it out on longer trips and have had the charging system checked while it was running. The battery wasn't getting the full 14ish volts even while holding it at a higher rpm.
JackFish
Post #20 by JackFish » Wed May 16, 2018 5:22 pm
How are the battery cables?
Who tested the alternator for you?
1999 Dodge Ram 2500
65_Stang_170
Post #21 by 65_Stang_170 » Wed May 16, 2018 9:03 pm
JackFish wrote:How are the battery cables?
Battery cables are in good condition. I've had the alternator tested in and out of the car several times at both O'Reilly's and Autozone. And my father-in-law and I tested it at home, and it checked out. I also put in a new alternator wiring harness. I got a new plug for the VR that I need to wire in to see if that's where the fault is.
65_Stang_170
Post #22 by 65_Stang_170 » Thu May 17, 2018 4:22 pm
Got her tuned pretty good for now, and she's running pretty strong! Best it's ever felt?
Thanks for the help everyone!
Soldmy66
Post #23 by Soldmy66 » Thu May 17, 2018 6:00 pm
Might want to double-check the fuel filter too.
chad
CONGRATS !!!
Post #24 by chad » Thu May 17, 2018 8:46 pm
so:
jet
harness
VR
(& pcv?). Is that what it wuz? OR - timing too?
65_Stang_170
Re: CONGRATS !!!
Post #25 by 65_Stang_170 » Fri May 18, 2018 2:15 pm
chad wrote:so:
jet
harness
VR
Timing was solid the whole time. The jet made a big difference. New vacuum hoses also helped the situation.
Haven't figured out the charging system issue yet, but that's future me's problem... :lol:
wsa111
FSP Moderator
Post #26 by wsa111 » Fri May 18, 2018 8:24 pm
Amazing the jet change was what i said before, now is the time to upgrade your distributor for a real performance gain. Bill
Users browsing this forum: No registered users and 23 guests
