It has been published that headers will not work with A/C, this is an incorrect statement. What is true... is that headers will work with either Stock or After Market A/C, but it is not a simple bolt on upgrade.
Modifications are required to the compressor and/or alternator brackets to achieve adequate clearance.
The following pictures will show how I modified my alternator bracket to allow the proper clearance between the header and the alternator. A similar solution is viable...​
You do not have permission to view the full content of this article. Log in or register now.
  • Like
Reactions: ray6966
