whazup8003
Got my mustang on the recently, and everything seemed to be going good other than the face of a small what seems to be like a missfire once in a while. After driving it for a couple weeks things have just gotten worse and worse.
Here's the setup:
new rebuilt 200 inline 6 bored 30 over
Autolite 1100
New original style distributor cardone (autozone)
T5 transmission out of a 1987 4 cyl mustang
So I finally had all the leaks buttoned up and everything running smoothly
Except a slight missfire through the Rpms. It would miss at idle a little bit too.
I was driving it the other day and it started bucking very violently which is the first time in weeks of short drives it has done this. Almost like enough gas wasn't being given to it off the clutch release. Reminded me of when I was first learning to drive stick and it would buck on unsmooth clutch releases. But I'm kinda ruling out clutch because after this incident it runs real roughag idle to. It will runs smooth and a few seconds later just feel like its misses pretty heavy.
Also on another note I put a new pcv valve on for good measure and it opens and closes to fast and at such a pressure that its makes a ticking noise similar to a knock or a ping noise but I can hear it from inside the car an it's definatly the pcv.
Could this be a cause of the problems I am having?
Been trying to figure this out for quite a bit. Had a few questions that maybe Somone hear could answer that could help me try to solve this problem.
1. What kind of oil is everyone using in there rebuilds?
2. What timing is standard in a rebuilt 200 with a t5? I've heard 12 degrees and 6 degrees.
3. Is there a good way to test a new fuel pump under load? I got a reading of about 6 or 7 at idle. Fuel like is brand new from tank to pump.
4. I have to replace the exhaust gasket donut between manifold and stock pipe. It's leaking pretty bad and was wondering if this could cause my rough running.
5. Have a open hole ahead of distributor in the middle of an emboss. Did a little research and this hole is where a oil draft tube used to go. I plugged it with a freeze plug like is recommended but have a fear it maybe leaking around it still. Would this cause a problem?
6. There is 2 bolts holes underneath the exhaust manifold on passanger side of engine and I don't remember anything going there. Does anyone know what these 2 holes belong too?
I know this is a lot to take in but I wanted to get as much as I could think of out there while it was fresh on my mind. I am probably forgetting something. Any help or comments would be greatly appreciated.
I did quite a bit of searching the forum for this problem in other posts but really couldn't find my exact dilemma spin hope I'm not reporting something someone has already covered.
Thanks in advance Scott
Here's the setup:
Autolite 1100
