That’s how I sanded mine down. Worked good!
I went with the 64 pump and intermediate shaft to run the duraspark II in my ‘61 223. Totally happy with it! I didn’t want a GM HEI style cause of the large cap look and was trying to find something that looked closer the the factory look.I keeping with my one piece at a time policy, and not being in any hurry, I have a 64 pump coming tomorrow.
Moving on to the next hurdle, is there any reason not to use a rebuilt distributor?
I plan on the point type and the only not rebuilt options anyone seems to offer are HEI conversions.
Is one year any better than another?
Cardone seems to be easy to source and offers distributors for the 240 and 300. I have had good experience with them in the past, as well as one or two purchases recently. As far as I know, they are still doing all their work in the U.S.
Lou Manglass
I’m not a on this but I know performance distributors had a hard time finding or getting cores of the duraspark II. I’m not sure if it was covid /supply chain issues and I forgot who told me but Cardone new parts may have gone China made now, I believe their reman stuff may still be American made, just a heads up maybe some one can confirm this or correct me if I’m wrong?Cardone seems to be easy to source and offers distributors for the 240 and 300. I have had good experience with them in the past, as well as one or two purchases recently. As far as I know, they are still doing all their work in the U.S.
Lou Manglass
There usually isn't much wear on the lobes of a points distributor, they are metal and the rubbing block on the points is plastic. As long as it's been properly lubed when the new points are installed it can go on almost forever.Thanks.
I guess the part that I worry about on a rebuild is the lobes that wear against the rubbing block. I expect that all of them will use new bushings.
Are there any with bearings instead?
Didn't the points type with dual advance run from something like 68 to 76?
Bill, FYI points can be fired by the TFI module as well. Module controls dwell so point gap is moot, and only milliamps of current across the points, full battery voltage at the coil. Easy wiring. Making the upgrade gave a noticeable improvement over factory points/ballast resistor.Inquiring minds want to know.
I want the point type.
I plan to have it trigger an MSD 2A, but want the option of bypassing it in case it tries to leave me stranded in the middle of nowhere.
