mkeily":o5qeil9i said:Tom, where abouts are you located. Are you in NSW? Sydney area?
Hey Mkeily,
I am on the South Coast of NSW, But sometimes travel up to Sydney. why did you want to know?
Cheers
Tom
aussie7mains":27v7dukc said:tomxy
Why are you wasting your time trying to port with a drill, you wont be able to do any valuable work like this.
1 The 2v inlets are just fine as they are, any grinding is only likely to make them worse, BTW polishing is only cosmetic, it actaully makes things worse.
2 Exhaust are bad and need help, but grinding near the gasket face is next to useless, the valve needs to be bigger and the seat blended to match, with guide reduced.
3 The center exhaust port needs dividing and you must have matching divided headers, this can be done by cutting a piece if 12mm plate to fit an have it welded in.
The only way to do this work poperly is with a high speed grinder (20000rpm) and siutable cutters or for the amatuer stones.
I do have experience with this work and this head, just in case your asking.
A7M
aussie7mains":2h923mge said:Truly I cant stress enough that you will make the inlet side worse.
the 2v inlets are already too big, so DONT enlarge them at all, the shape just behind the valve is the most important area and without putting in larger valves there isnt much you can do, If I remember your car is a streeter, if so then just leave well alone. Its almost impossible to properly match the port to intake joint, without putting dowels into the face to align them.
The exhaust really beeds 1.5 valves then blending to match the new larger valve seat , the guides can be cut down and the port straightened up somewhat, you'll notice theres a strange bend just near the outside of the of the port on one side, this can be removed to starighten up the port. your 1v headers should work IF the centre port is divided right up to the flange, so you can divide the centre exhaust port and give a header with 2 groups of three cylinders
hope this helps a bit.
A7M
mkeily":1ywsx8ti said:Sorry Tom I've been a bit slack replying. I was asking where you live because I am always keen to catch upwith forum member if possible if they live in the Sydney area. I live in Cherrybrook which is in the north West of Sydney.
If you were driving up one day we might be able to catchup.
Mark
aussie7mains":1ywsx8ti said:The way i did it years ago is:-
Cut a piece cardboard to get the shape you need to fill the space right to the exhaust flange.
Then oxy cut a piece of 12.7mm steel plate to that shape and dress up so it fits fairly well, clean up edges ready for welding.
Get some special cast iron welding rods, you will need about 12 for this job.
Weld in about 4 tacks to hold the steel in place.
Now run each weld but only about 10 mm at a time, between each weld pien each weld to relive strees, if youve got a propane torch heat the head up somewhat.
Dont undertake this unless youve got the right gear and can do reasonably competant at arc welding.
A7M
