Thats true enough, but remember that the suction of the blower can create a lower pressure than the DP used to rate the common carbs. Its interesting that only the USA made carbys are rated this way. my mixer has a 60mm throttle bore plenty for my setup. Delorto SU do not give cfm ratings. As I said mine has a rating, and theory would have it that its too small, but it does not limit boost in any way I can tell. Im seeing manifold pressure above atmospheric even at tiny throttle openings, and I have a pressure point on the suction side and its rarely lower than 5 inches Hg. I have a manifold ABS pressure gauge from a ww2 bomber, it has two needles. so I can watch both, its facinating to see what is going on, it wasnt what I expected. A bit of research into LPG in the USA shows that its not that rare, and the average price seems to be about the same as here,$1 per litre or $4 per gallon. Its listed as 104-112 octane on the site I found.
