Figure this will be fairly controversial!
I was at a hotrod show this weekend, Lonestar Round-up in Austin, TX... It was more of a 'rat rod' kinda show, lots of questionable mechanik'n on display, but one thing that i couldn't help but notice was the prevalence of these cheapo ebay turbos. Saw lots of twin turbo V8's... a couple of them were actually really well built (out of junkyard parts) one in particular had pretty clearly been driven on the road quite a bit, it was covered in road grime, bugs and the plumbing had obviously been run hot.
I should have brought a camera, but you can tell these things pretty easy by the weird names on them like 'master power' etc. and the crappy finish quality.
but it did pique my interest.. obviously these guys are having some success with them? Also the user 'first fox' seems to be having good results with his.
I had more or less completely discounted them, and put them in the category with cordless tools from harbor freight, but now i'm seriously considering it for my 240 'stage 2' build this summer.
The advantages are:
1) The t3/t4 style turbos are better suited to a wide RPM range, and several A/R ratios are available so i could choose something sized better than a junkyard turbo, the TD04E-16T that i had previously picked is starting to look like a bad choice the more research i do.
2) brand new, for what its worth, no rebuild needed (a junkyard turbo @$70 + rebuild at $60 = total cost of new china turbo)
3) easier to adapt and connect than the 'oem' turbos that use different flanges... bolt on changeability between various turbos if it blows up or turns out to be sized wrong.
4) available from various online sources for $120 or less... completely bonkers!
The disadvantages are:
1) china, china china... could get sent a box of complete scrap metal
2) probably less efficient, possibly leaky or completely wrong trim/AR compared to what is advertised
3) could explode and send shards of compressor into my engine
4) external wastegate needed
5) probably going to be noisy and un-balanced
Seems like most people that have bought these turbos are idiots with no experience, probably many of the claims of problems (leaky seals, bad bearings, etc) come from folks that didn't set them up correctly to begin with. I haven't heard anyone that specifically has run one, knew what they were doing, and put some serious miles on it, except for First Fox.
Just curious if my points are valid, or if there are any major holes in it, and if any of you guys have more experience with these, specific brands/sellers or identifying characteristics that you can look at a listing and say 'that one is definitely one of the better ones' or 'that one is total junk'
I'm trying to put together this 240 without opening it up, more or less just to experiment with the concept, see how the big six handles boost and make the mistakes before i start into a full-longblock build of a 300. I've already learned quite a bit just from daily driving my 'stage 1' build with the converted 2100... stuff like realizing that the Big 6 likes to rev a lot more than i thought, so this 'stage 2' engine will hopefully inform whether or not i need to go with bigger valves, cam, lower comp pistons, etc. to deliver the 'factory stock turbo' level of performance that i'm looking for.
ach i've wrote a tome:
tl;dr: anyone used the cheapo china turbos on ebay? will they work for a mild build or are they complete junk? if some are good/some bad how do i tell them apart?
The advantages are:
If it helps I need to either find second hand forged pistons or try and find a company that'll make them cheaper than classic inlines. There's no ebay replacement for that
