Draw through all the way. With old parts. Carter fuel pump. And some real work on the two carb adaptors.
Two Byrds in the Bush is better than one they can see you have in hand.
I have lost faith in the concept of just buying new stuff, when extra things then have to go with extra things. The USA is a glorious dumpster of anything you need barn find serendipity. You MUST network and ask, and be informed, and never back down until you get something that solves a problem without creating others.
Draw throughs are flow biased, and dangerous to operated above 9 to 12 psi if the fuel isn't directed to each cylinder with 80% flow efficiency for each cylinder. But if you use two 0.48 AR exhaust T032's from an old 2.3 carb turbo, you'll do fine. But you've got a few things to learn on the 6 bolt location and intake arrangement. You have to ask Powerband a few placement questions, and network to make this work great
Tell anyone its a generic type 1 sealed TO32 "B" with an early variation of Fords T03-60. My friend from Downer NZ has a 1981 Turbo Trans Am BF Goodrich with factory WS6 rims, BFG 295/50 15 tires and a factory turbo down here.
Same crap.
Counterwally wants to know car(which he will tell you THE COMPUTER SAYS is wrong),
turbo name (which he will tell you THE COMPUTER SAYS is wrong),
VIN number (which he will argue over) etc etc etc...
Fords OEM part is supplied by DSO, so top two fields are blank.
Use these numbers. If anyone asks for a VIN number, use the 1981 VIN 1FABP10B4CF109967 Mustang.
#20445 is the SN part number for a counterwally, 1980 Ford Mustang or Mercury Capri 2.3 Turbo Carb
Customer part number # 465564-6
Give them a generic part number list. Anyone asking anything else are just being awkward. Tell anyone you'll pay cash only for the turbo, carb and intake, or no deal. Unscrupulous People try to split parts to get three bits of the ch3rry. Been down that road with 2V heads, intakes and tube headers. Anyone who doesn't supply all parts isn't to be trusted AT ALL because its likely stolen or split for unconscionable gain
KIT #1: 1-PIECE ENCAPSULATED CARBON SEAL APPLICATIONS:
Buick Regal, LeSabre, and Riviera up to '83; Ford/Mercury '79-'80 Mustang & Capri 2.3L; Nissan 280zx '81-'83; Nissan 300zx '84-'85; Pontiac TransAm '80-'81
https://www.oocities.org/twincharger/turbo.html
{This Page is an outdated, user-generated website brought to you by an archive.
It was mirrored from Geocities at the end of October, 2009.
For any questions concerning this page try to contact the respective author. (To report any malicious content send the URL to "oocities(at gmail dot com)". For question about the archive visit: "OoCities.org".}
Gregpro50 AND m81McLaren gave me all the info.
http://vb.foureyedpride.com/showthread. ... rs!/page10
One other forum member has the whole 1979 turbo carb 2.3 kit, but your bettor off just posting an All Points Bulletin , and trying your fortune.
There is no support or backup for new turbos. Despite al the promises. In a year, you'll not get the same parts again, so try using old Hot Rodders logic, and buy junk cheep, and have it magnaflux crack tested and dye penetrant tested, and then alcohol cleaned with new seals and bearings checked.
