electrorc
Haha yeah project definitely grew... keep looking at it and thinking I may as well change this and change that while I have the surrounding area torn apart haha. I'm definitely hoping I can get it pretty well finished and driving here in the next few weeks.
I got the short block and head back from the shop a little over a week ago. I'm not to a point of being ready to assemble it yet, but I want to get some input before I do.
1) Are regular stock-type replacement lifters going to be fine for a mostly stock rebuild with the 264/264 cam for a daily driver? Or do I need to be looking for something a little better?
2) What kind of pushrods should I be looking to get? Obviously I don't want the whole bent and broken pushrod thing to happen again. Do I need to get the 0.060 shorter ones, custom length ones, heavier duty ones, anything like that? I had my head resurfaced though the shop didn't say how much they took it down. I know the engine had been rebuilt before, and of course it's a '63 head, so I'm assuming it's been milled before. I'm going to try and cc the chambers sometime. I'm also still using the regular non-adjustable rockers.
3) It's looking like I'm going to have a valve spring problem. I got the 302HP springs from Classic Inlines, but the shop is fairly certain that I'm going to run into a coil bind issue. Coil bind is listed for the springs as .480... cam lobe lift is .480. I know a couple people here are running some form of 302 springs with the Clay Smith cams. If they won't work, are there any other springs that will work with this cam and won't require machining on the head to fit?
There's a few pictures of the engine here: http://65ssg.dyndns.org/index.php/2011/06/engine-ps-rear-torque-box/
Thanks!
Thanks!
