Crustang to Mustang
Sound advice there, Cox.
I can see what I can do.I'd find the money for a full cam/lifter set and rockers just to not have to pull the head later.
Send me a PM with what you are trying to achieve and I’ll see if I can help out in any way.I can see what I can do.
Thank you so much! I will be going on a trip in a few days but I'll get back to you.Send me a PM with what you are trying to achieve and I’ll see if I can help out in any way.
I am still going through a heap of parts, but I might have some parts I’d be willing to donate, to get you started.
Why would you cut up cast iron Boss 302/Cleveland heads to make a 6 cyl when an alloy head with the same canted valve design already exists? Here's pictures of a Boss 302 head and an Australia 4.1L Crossflow head. See the similarities?Right now I've just got a '73 large log, but I'm considering trying to fabricate a new head out of a couple of Boss 302 heads.
I can't find one of those, nor could I afford it.Why would you cut up cast iron Boss 302/Cleveland heads to make a 6 cyl when an alloy head with the same canted valve design already exists? Here's pictures of a Boss 302 head and an Australia 4.1L Crossflow head. See the similarities?
Wont fit the 240-300 six, bore spacing is much bigger than head.Why would you cut up cast iron Boss 302/Cleveland heads to make a 6 cyl when an alloy head with the same canted valve design already exists? Here's pictures of a Boss 302 head and an Australia 4.1L Crossflow head. See the similarities?
Correct!He's not building a 240-300, he's talking about making a crossflow for a 250.
The closest way to do what you’re talking about is to copy the Aussie 2V Head Intake Flange onto your proposed cut off Log Head’s then you could use one of the many available Aussie 2V Bolt on Intake Manifolds that Aussie Speed Makes.I've got a friend who is a welder and works at a metal shop. If it's okay with his boss, he might can use the equipment to chop of the log and weld a flange on the head so that I could then weld a new intake manifold. Would it be worth it?
You may be surprised. I am sure the Aussi head will be more reliable than a welded V8 head.I guess I'll just have to keep looking for that crossflow head.
