So today while tackling a voltage problem I noticed something I never noticed before
It seems that there are two holes that apparently were drilled right through my cylinder head! The one pictured is towards the front the second towards the rear. Is this factory? I do not think it is.I suspect this was someones idea of getting the head to breath better, but let me give a little background.
I am technically the second owner of the car. I purchased it from a person who had ownership for only a month or so. Prior to that it was with the original owner. I have very little history of the car however I do know that I got the car with a 68 block and 61 head in it, pretty crappy correct? There were some notes that indicated that both the block and head were replaced by rebuilt parts shortly before I took possession. Well after I took ownership I dropped in an electronic ignition, got rid of an aftermarket air conditioning unit, re-did a very funky transmission cooler set up dropped in a correct radiator and tranny cooling lines, pulled out the entire charging system and reinstalled all new, tuned the carb and advanced the timing. Well the results were that I have no problem getting up to 75-80 mph very quickly! At 80 mph there is still more left in the engine but I am not really crazy about going much faster in 45 year old technology! After I got to this point I stopped with the knowledge that I wanted to do more with the engine but first I wanted to take care of some safety items, brakes,suspension etc.
Well know I am at the point where I am ready to turn my attention back to the engine. I currently have a D7 head rebuilt by CI with a 2V conversion a better electronic ignition with the correct vacuum advanced and the money saved to purchase a Weber 32/36. But before I go ahead my question is, Will I do much better with these mods than the car already does? I have no idea what was done during the last rebuild but like I said previously she goes pretty good. What do you guys think? And what do you make of the holes in my head?
