A good idea that works, and has additional benefits in keeping operating temp more stable.How about switching to an electric fan to avoid the parasitic loss there?
"...Automatic trans these days are more efficient and some even surpass manual trans (or so they say)..."The drag caused by higher viscosity oil in the transmission would be almost unmeasurable
OK, then how come the trucking industry has largely gone to Automated manual transmissions rather than full auto? Losses is the answer, every bit of fuel consumption counts for truckies."...Automatic trans these days are more efficient and some even surpass manual trans (or so they say)..."
yes, the stats have shown a decade or so that autos now surpass manual.
At one time (remember Mr. "MPGs" a stang owner here?) we hada list: a/c v open window, tires/tyres, belts, pumps, rotating parts lube, etc, etc.
There wasa comment w/each: Ex - windows win till over 45 mph, p/u truck tailgate down no, tonneau .5 mph, etc
It is largely due to initial step-in cost and secondly the cost to rebuild the automatic is tremendous over the standard. Plus, if you lose a gear in the automatic your done for a week or ten days; the standard you still might get your load in.OK, then how come the trucking industry has largely gone to Automated manual transmissions rather than full auto? Losses is the answer, every bit of fuel consumption counts for truckies.
automobiles, from the international auto writers (IDK - "Motor Trend", ASR Mag, Road'n Track or whatever their names are) have been reporting on it a good while. Common knowledge (I'd say, but I'm pretty common).OK, then how come the trucking industry has largely gone to Automated manual transmissions rather than full auto? Losses is the answer, every bit of fuel consumption counts for truckies.
Also weight was the primary reason when I was in the industry '80's-'00's. The Allison autos then were much heavier than the Eaton manuals. They proved dependable in bus applications, but the big trucking companies stayed away from them for uniformity in their fleet repair shops, the cost, weight, and unknown durability in the high-load semi application. I don't remember fuel economy being a big playing card.OK, then how come the trucking industry has largely gone to Automated manual transmissions rather than full auto? Losses is the answer, every bit of fuel consumption counts for truckies.
I just saw this.At 14 volts, 53 amps pulls 1 HP.
Higher voltage, lower current for equal power, lower current, less losses. This is why 24v is used. think of the HV transmission lines, 330KV. Still efficiency of under 60% is quite low compared to AC generators for 50Hz, which can generally be up over 90%.I just saw this.
The automotive alternators used in vehicles from the 1960’s up to present have an efficiency around 50 to 55%. Some more, some less. Some of the most efficient alternators are used in heavy trucking and busses.
Alternators by Model Family | Delco Remy
From brushless designs with fewer moving parts to remote sense to improve battery charge time, Delco Remy technology is second to none. We continue to leverage our experience to provide our OE and aftermarket partners with innovative solutions for today’s vehicle electric system challenges.www.delcoremy.com
It’s known that in general, 24 volt alternators have higher efficiency numbers than 12 volt. Some newer alternators are using square wire wound on the stator and rotor. This helps, but generally a 12 volt alternator will be less efficient than alternator with a higher voltage output.
Here is some good reading:
Generally what I've found is that with alternators, the bigger they are the more efficient they are, this is in the above 50kw. this could accont for the difference you found, you I take it were unable to determine the input power from the engine, also there is no quaranty that any two power uinits are the same, this is especially true of petrol engines. The difference you have quoted is about 12% which would be within the spec of most petrol engines (plus or minus 10% output) Diesels are generally better than this. I was involved in specifiying and building standby gensets for telephone equipment in PNG, most of them were over 35kva, they ran direct coupled at 1500rpm (50Hz) 3 phase and 240v. The larger ones were mostly caterpillar although some had a variety like Leroy Somer, Mecce Alta even some Australian local units. The smaller sets with single phase alternators were less efficient. We were not overly concerned about fuel consumption as most only ran a 1000hrs a year at most.Exactly,
A good friend and I started a microcogeneration forum in 2009 and we did an experiment. We both purchased the same make, model and horsepower engine. He used a 7.5kw generator head and I used a 12.5kw generator head. We both operated them 1 to 1 ratio. He direct coupled the 7.5 with a love-joy coupling, while I used an 8 groove K-belt setup. We both ran the engines to overload and we were surprised that the larger head belted to the engine engine out-pulled the 7.5 direct coupled head setup by 982 watts. Even if our numbers were off 35% because of the differences in the engines output, 638.3 watts is still pretty impressive. Some members in the group thought the direct coupled, smaller head would out pull the larger belted head due to less friction loss on a smaller fan, smaller bearings and less rotational mass. The study showed that generator heads are generally more efficient not being pushed to full output.
To this day, when I build a genset. I normally oversize the generator head for an application and de-rate it by using a smaller than required breaker to prevent engine overload.
Yes generally true, if you get the BSFC curves they usually bottom out around peak torque, and above 75% load. Ive also messed around with natural gas engines, mainly in busses and trucks, the curves were similar there, One 9.6litre renault engine was getting 40% thermal efficiency on gas, which was as good as when on Diesel. The standby sets I was involved with were mostly Lister air cooled engines, but i prefered Deutz, especially the 912 series. Some of the cheapie engines like the Ford Dover engines were pretty good too. i did one caterpillar d353 engine, bloody huge thing, came out of a NASA tracking station, was orignaly 60Hz, but we slowed it to 1000rpm to get our 50hz. Heres a question for you, why did north America go with the 60hz, 110v split phase sysetm, when just about the rest of the world is 50Hz 240-250v.The engines used were Changfa S195 single cylinder liquid cooled diesels.
The Chinese diesel turned out to be very efficient 100% loaded. I don’t have the g/kWh numbers, but it was up there with some of the best small diesel engines made. The engine didn’t do very well at all lightly loaded. With our experience, in testing, with the diesel engines we’ve used, most got better numbers when fully loaded.
Because we didn't mind spending the money on the extra copper it takes to run a lower voltage, split phase system.why did north America go with the 60hz, 110v split phase sysetm, when just about the rest of the world is 50Hz 240-250v.
Hmmmm. And now we pay for it.Because we didn't mind spending the money on the extra copper it takes to run a lower voltage, split phase system.
Same with automobiles. Why did we have the 400 to 500 cu in V8 powered very heavy land cruisers while the rest of the world had more economical forms of transportation.
Yes i know the relationship between frequency and RPM, this mainly applies to 3 phase squirel cage motors, but going slower does not reduce efficiency, or neccesarily power. You guys also have this strange (to us) system where you bring in single phase at 240v then use a centre tap transformer to spilt that into two legs at 120v with opposite cycles, we dont do this. We have 3 phase supply to some homes and most business at 415v (across phases) but we split the phase so that one house might be on the blue phase, the next on red, and 3rd one on white, the other leg being neutral. We also have an earth. Some rural areas use a SWER, single wire earth return, cheaper. Most appliances are single phase and our normal outlets are limited to 10a, however we do have 15a outlets for small welders and AC units for example. EG I have a lincoln powermig 180c welder, it uses a 15a outlet at 240v, I think the US ones have to go to the 220 supply. The metric friendly might explain some. But all electric stuff was always metric. Do the USA still use BTUs in calculations, thats a unit that is very difficult to use.Back then in the 1890 with the common Arc and Incandescent Lighting they were using they found there was also less Flicker at 60 Hz. I also heard that they later found out that a clock is also more accurate on a 60 Hz frequency (60 minutes, 60 seconds). For an Electric Motor the basic, RPM is in direct proportion to Hz. If you decrease the power supply frequency, the motor will slow down and if you increase the frequency, the motor will speed up. So the RPM change is proportional to the Hz change. The primary difference between 50 Hz, and 60 Hz. is, that 60Hz is 20% higher in frequency. Example a 60Hz motor will run 20% slower on a 50Hz power supply, this also results in 20% less power and that’s where the up to 20 % less efficiency comes from. It’s been said that AEG in Germany (an Edison Founded company) choice of 50 Hz. was for convenience relating to a more of a "metric-friendly" number rather than 60Hz., still there was also that Battle between Tesla and Edison too. AEG had a virtual monopoly and their standard spread to the rest of Europe.
