deanospony
Supporter 2023
I’m using a DUI with a Weber 32/36 and am thinking of switching to an 18 volt system. Other than the cost, is there any reason why I shouldn’t do this?
I agree.So I take it you want to power the ignition with 18v, but the rest of the car with 12? Sounds very unnecessary.
The DUI module limits the current flow to the ignition coil to 8 amps whether the supply voltage is 12 volts or 18 volts so there is no advantage as far as spark energy.I’m using a DUI with a Weber 32/36 and am thinking of switching to an 18 volt system. Other than the cost, is there any reason why I shouldn’t do this?
Never knew any of this and I've been messing with oldies for almost 40 years. I love coming here and learning stuff like this. I'll probably never get to use the information but it's cool as hell to know!sure forum folks posting get the point, for others:
AC current can simply / cheaply be converted to less or more Voltage . 12V to 18V or 3V is a simple matter. The Spark Plug coil obvious example converting 12V or less to a couple of thousand volts - thousands of times / sec with interrupted DC.
DC current Voltage conversion is not so simple and less practical in past. To make AC out of DC for voltage step-up, originally -" Vibrator" devices simply opened and closed a set of contact points to make AC and then could be raised. With modern switching circuits, DC voltage conversion is simpler and incorporated into device if needed. Virtually all analog and digital electronics operate on DC internally.
hav e fun
the '50' Cvy analog tube radio has a smooth syrupy quality with music made for tubes. Occasionally at low idle , the 6V system inductive loss would 'freeze the vibrator' , meaning contact points would arc and weld together. Opening the vibrator can and using points' file could fix the radio ...
(now has replacement electronic device inside original vibrator can not susceptible to voltage drop - so far)
