granadastraightsix
thanks to all the help of everyone and reading on classic inlines i think i finaly came up with what i want to do for this year take a look and let me know if anything else you see is missing from the list, thanks for all the help
Level II - Street Use, Manual or Automatic Transmission
with a Stock Converter and 2.80 to 3.20 Rear Gear Ratio.
•Bottom end - Stock, balanced rotating assembly. Moly rings, cast pistons.
•Cylinder head - Three angle valve job, stock compression ratio.
•Cam - 264/264 lobe 110 hydraulic aftermarket cam (classic inlines.com $237.00)code csc-200-clk
•Ignition -msd/6al($232.00) with msd blaster three coil($48.99) upgraded plug wires(blue accel$45.00) and distributer cap and rotor(brass)
•Exhaust - Dual outlet headers($365.00 classic inlines.com). code fsp-200-ssh
exhaust system. Turbo or Flowmaster style low-restriction muffler.
•Carb - weber aggressive carb(cliffords performance $559.00) code 32-f
Improved breathing due to carb and exhaust upgrade. Better ignition and timing curve with both centrifugal and vacuum advance. Increased low-end torque with peak torque at 2000 rpm, and peak HP at 4200rpm.
