Ive been piddlin on a 144 for a guy.
He had a guy replace the shortblock. Then he gets it back, has me look at it, cause the engine now vibrated, rattled and idled horrible.
I realized the rockers were too noisy, sure enough, im not sure they attempted to set them. So I did, it smoothed out alot and no more valve train noise, but the vibration was still there, just not as bad.
Then, I did a compression test cold, all were 130psi, except the last cylinder, it was around 100 or so, I put oil in the cylinder and the psi greatly increased. I figure while thats not a good psi and it needs a machinists touch, I wouldnt think it would cause it to vibrate like it does, so I continued, trying to get it to run for the guy, for a little while. I physically verified tdc matched the crank mark to timing marks, think i aimed for 12 btdc based on info i found online, and in doing so, noticed both motor mounts didnt look right, and were completely broke, the dipstick that put the engine in, put a 1/2" piece of rubber under the bottom of the mounts to "shim" the engine up where it should be. But considering the rubber was completely separately on both mounts, the engine was literally held down by gravity, when I unbolted the mount from the block, the mounts fell to the ground in two pieces, both sides were like that.
Once motor mounts were replaced the engine smoothed out even further, id hoped that would end the ordeal but still vibrates more than it should.
I removed the fan belt, thinking the fan might be off balance but nothing changed.
So I notice it smooths out with a little throttle, at this point, im thinking idle rpm too low, so Im thinking see if the idle needs adjusting at the carb linkage, so I follow the linkage to the carb side facing the firewall, see a bolt that would appear to adjust the idle speed but theres nothing above it, ive not dealt with a holley 1bbl, and im having little luck finding an exploded view that looks like the carb im dealing with, but the similar carbs I have seen, show a quarter circle cam that the idle speed nut/screw is sdjusted against, this carb has nothing there.
I was hoping someone here may have a photo, of the carburetor, the side that faces the firewall, link or something that I could look at to see if im missing parts or which parts, the tag on this carb reads C2DE-M A2FC.
Ive searched, will continue to search, but having little luck, this carb is a manual choke with distributor vac control, supposedly off a 62 falcon 144.
Im also hearing what sounds like a miss out the tailpipe. Distributor appears newer, but I do plan on changing points or talking him into doing a pertronix conversion.
Any help appreciated, I have nothing to gain $$$$ wise, im just helping a guy out.
