Hmm. The second graphic I posted for the programmable control wiring is from Ford Motor Company Diagnostic Systems Department, TFI white paper dated March 13, 2002. I assume it would be accurate, but I'll check other references.Unfortunately I numbered the module from top to bottom as did gofastforless
No biggie- there's no "accurate or inaccurate", just reversed pin # reference. Us "shadetree" guys just numbered from the top, since numbering top to bottom and writing left to right is instinct. . . And if I may say so, logically it seems Ford would have numbered from the top too. There's no conflict with where the wires go, and that's the primary thing.Hmm. The second graphic I posted for the programmable control wiring is from Ford Motor Company Diagnostic Systems Department, TFI white paper dated March 13, 2002. I assume it would be accurate, but I'll check other references.
Thanks for that, means I've posted the order wrong. I can't see that either w/o help! LOL.OK, no problem if you have a diagram to look at.
If it helps others sometime, many (not all) connectors will have a tiny reference number molded-in at one or more pin locations. This is a crappy photo, but shows a TIF connector with a "1" by pin 1. Again, not on all, or could be by a random pin (4 or whatever) or back-side, or in the recess, just so instructions without images can be followed, usually in electrical testing. Likewise, they often have a tiny part number (or partial) molded-in to help find replacements. My eyes can't see them anymore without a lighted magnifier.
It's just been a slow progression of advancements across the decades. However, it can be a bit like a fire hose of info if you try to catch-up 50+ years all at once. A short review of progression over the years up through the '90s:did not come back till 21st century. This means I missed alot of automotive development (no more carbs, lots
of sensors, computer aditions, & plenty more). I have been catchin up thru all your (& bub's) kindness.
You forgot magneto's, they were used in the 20's cars up to the 80's in race cars without a battery.It's just been a slow progression of advancements across the decades. However, it can be a bit like a fire hose of info if you try to catch-up 50+ years all at once. A short review of progression over the years up through the '90s:
Early 2000s - you came back. Lots more activity 25 years ago, with the most substantial being the introduction of inexpensive wide-band oxygen sensors for home tuning, enabling and expanding electronic kits and systems to run and tune most any ignition and fuel injection at home or track. MegaSquirt arrived about then, changing the face of engine control options for hobbyists to serious racers.
- Early 1900s: Kettering (points-switched power to an ignition coil to build energy and then discharge it at high voltage.
- 1900s to 1960s: Various minor improvements with mechanical advance for rpm changes and manual driver timing adjustment.
- Early 1960s: Big jump in control with vacuum advance to adjust for load changes. Effectively, mechanical "3D" timing.
- Mid-1960s: Dual-points and invention of solid-state CDI ignition (used in MSD soon). Both used primarily for high-rpm advantages.
- Early 1970s: Solid-state points switching replacement arrives. No more points! Ford introduces DuraSpark-II. MSD arrives.
- Mid-1970s: Electronic dwell control, enabling much stronger high-energy (HE) sparks. Used by GM (4-pin HEI) in everything.
- Late 1970s: Ford introduces DuraSpark-I high energy systems in CA emissions applications. Retains DS-II for 49-state Fed emissions.
- Early 1980s: Hobbyists creatively apply HEI modules and coils to get better sparks from points and DS-II.
- Mid-1980s: Ford moves to HE for more applications with electronic timing controlled TFI. No more weights, springs and canisters!
- Late 1980s: All OEMs move to electronic timing control (TFI, GM 7/8 pin, etc). The days of mechanical and vac advance are almost over.
- Early 1990s: Ford and GM move to distributorless coil packs for most applications. This, like TFI, requires electronic timing control.
- Late 1990s: Ford moves to COP (Coil On Plug) and GM to mixed CNP (Coil Near Plug) and COP per-cylinder coils. Distributors are gone.
Like Starbucks, MS built the vast acceptance of carb-style tuning of EFI (on everything since the '80s) and permitted both more-advanced DIY tuning of factory systems and carb or distributor conversions. The mid-2000s see PC programs first appear to allow hobby-level advanced tuning with data analysis guidance from that handful of sensors. And similar to Starbucks 20+ years later, the market is now populated by many, many simple to complex systems from commercial kits to DIY and experimental stuff.
OK, you're caught-up. Whatcha doin' next?
Mr. Kettering, who developed breaker points, and the electric starter motor in 1912- his son followed in his engineering steps. Do you know what he is responsible for developing that had as much impact on transportation as his dad?It's just been a slow progression of advancements across the decades. However, it can be a bit like a fire hose of info if you try to catch-up 50+ years all at once. A short review of progression over the years up through the '90s:
Continue to use the simple, effective and dependable mechanical systems of the '80's to fire the simple, balanced, durable century-old inline 6.OK, you're caught-up. Whatcha doin' next?
Any updates to this wiring diagram?A couple options for you, that have been mentioned:
First is points distributor with TFI module and TFI coil:
Next is either TFI or locked-advance DS distributors to a programmable ignition or full engine control, in this example Speeduino, but others are similar. With this, any coil, or even distributorless coil packs can be used, although the TFI coil is a good one. The controller settings are included, but ignore them for now:
The module wiring is nearly identical, but 2 wires to the controller, 1 to the coil. An example of an inexpensive kit to DIY assemble is the UA4C, with case, case end plates, pigtail harness and BlueTooth module if you want wireless tuning. The DS distributor is a VR system, so will also need a signal conditioner. While an even less expensive unit could be used, this one gives the option to do full EFI control if you decide to go that way in the future. Yes, it's a full EFI ECM, and we are only using the ignition control portion of it for this.
I hope to finish design and development of a complete and assembled (ready to install) programmable ignition controller available by summer, at a similar price or under $200.
NO. Duraspark and HEI are magnetic sine wave signals, the TFI is "hall effect" ON/OFF signal. One can't read the other. Points work with TFI, as they make a sharp clean on/off signal.Will the TFI module work with all its features when used with a duraspark magnetic pickup?
