dj65falcon
Ok guys i need your help on this. Have a 300 6 with a paxton supercharger novi gss. It is pushing 7 psi. And i have running a intercooler on it. I got myself a greddy rs 35mm blow off valve. Now at first i set it to soft setting. When i rev the motor and let off the throttle. A little bit was coming off the blow off valve.. But it was coming out of the air filter on the supercharger. So i went to hard and it did the same thing..it has 2 springs in the blow off valve. Do you think it has to much pressure with the 2 springs?And i should take the inter spring out and with that help with the pressure.plus i have a vac/boost gauge. When i rev the motor. Should it go on the boost side? Cause when i rev it. It give me 20 inch of vacuum. At idle it at 7. Any help would be appreciated.
